Subject: |
[Merge] lp:~epics-core/epics-base/dbConvert-memmove into lp:epics-base |
mdavidsaver <[email protected]> |
To: |
[email protected] |
Date: |
Fri, 13 Jun 2014 19:57:21 -0000 |
mdavidsaver has proposed merging lp:~epics-core/epics-base/dbConvert-memmove into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/dbConvert-memmove/+merge/223116
in dbConvert.c use memmove instead of for loop when no conversion takes place. On some archs this yields a significant speedup for array copies.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/dbConvert-memmove into lp:epics-base.
=== modified file 'src/ioc/db/dbConvert.c'
--- src/ioc/db/dbConvert.c 2014-06-04 19:18:43 +0000
+++ src/ioc/db/dbConvert.c 2014-06-13 19:56:49 +0000
@@ -38,6 +38,29 @@
#include "recGbl.h"
#include "dbConvert.h"
+/* Helper for copy as bytes with no type conversion.
+ * Assumes nRequest <= no_bytes
+ * nRequest, no_bytes, and offset should be given in bytes.
+static void copyNoConvert(const void *pfrom,
+ void *pto,
+ long nRequest,
+ long no_bytes,
+ long offset)
+ if(offset>0 && offset < no_bytes && offset+nRequest > no_bytes) {
+ const size_t N = no_bytes - offset;
+ /* copy with wrap */
+ memmove(pto, pfrom + offset, N);
+ memmove(pto + N, pfrom, nRequest - N);
+ } else {
+ /* no wrap, just copy */
+ memmove(pto, pfrom + offset, nRequest);
+#define COPYNOCONVERT(N, FROM, TO, NREQ, NO_ELEM, OFFSET) \
+ copyNoConvert(FROM, TO, (N)*(NREQ), (N)*(NO_ELEM), (N)*(OFFSET))
/* DATABASE ACCESS GET CONVERSION SUPPORT */
static long getStringString (
@@ -427,12 +450,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- while (nRequest) {
- *pbuffer++ = *psrc++;
- if(++offset==no_elements) psrc=(char *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(char), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -454,12 +472,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- nRequest--;
return(0);
@@ -638,12 +651,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- if(++offset==no_elements) psrc=(unsigned char *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(unsigned char), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -658,12 +666,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- nRequest--;
return(0);
@@ -870,6 +873,7 @@
return(0);
static long getShortShort(
const dbAddr *paddr,
void *pto, long nRequest, long no_elements, long offset)
@@ -881,12 +885,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- if(++offset==no_elements) psrc=(short *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(short), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -901,12 +900,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- nRequest--;
return(0);
@@ -1084,12 +1078,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- if(++offset==no_elements) psrc=(unsigned short *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(unsigned short), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -1104,12 +1093,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- nRequest--;
return(0);
@@ -1328,12 +1312,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- if(++offset==no_elements) psrc=(epicsInt32 *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(long), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -1348,12 +1327,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- nRequest--;
return(0);
@@ -1532,12 +1506,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- if(++offset==no_elements) psrc=(epicsUInt32 *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(unsigned long), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -1552,12 +1521,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- nRequest--;
return(0);
@@ -1782,12 +1746,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- if(++offset==no_elements) psrc=(float *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(float), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -2013,12 +1972,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- if(++offset==no_elements) psrc=(double *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(double), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -2228,12 +2182,7 @@
*pbuffer = *psrc;
return(0);
- psrc += offset;
- if(++offset==no_elements) psrc=(epicsEnum16 *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(epicsEnum16), paddr->pfield, pto, nRequest, no_elements, offset);
return(0);
@@ -2734,12 +2683,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- *pdest++ = *pbuffer++;
- if(++offset==no_elements) pdest=(char *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(char), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
@@ -2754,12 +2698,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- if(++offset==no_elements) pdest=(unsigned char *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(unsigned char), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
@@ -2940,12 +2879,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- nRequest--;
return(0);
@@ -2960,12 +2894,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- nRequest--;
return(0);
@@ -3186,12 +3115,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- if(++offset==no_elements) pdest=(short *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(short), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
@@ -3206,12 +3130,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- if(++offset==no_elements) pdest=(unsigned short *)paddr->pfield;
- nRequest--;
return(0);
@@ -3392,12 +3311,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- nRequest--;
+ COPYNOCONVERT(sizeof(unsigned short), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
@@ -3412,12 +3326,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- nRequest--;
return(0);
@@ -3638,12 +3547,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- if(++offset==no_elements) pdest=(epicsInt32 *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(epicsInt32), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
@@ -3658,12 +3562,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- if(++offset==no_elements) pdest=(epicsUInt32 *)paddr->pfield;
- nRequest--;
return(0);
@@ -3844,12 +3743,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- nRequest--;
+ COPYNOCONVERT(sizeof(epicsUInt32), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
@@ -3864,12 +3758,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- nRequest--;
return(0);
@@ -4095,12 +3984,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- if(++offset==no_elements) pdest=(float *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(float), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
@@ -4327,12 +4211,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- if(++offset==no_elements) pdest=(double *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(double), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
@@ -4553,12 +4432,7 @@
*pdest = *pbuffer;
return(0);
- pdest += offset;
- if(++offset==no_elements) pdest=(epicsEnum16 *)paddr->pfield;
- nRequest--;
+ COPYNOCONVERT(sizeof(epicsEnum16), pfrom, paddr->pfield, nRequest, no_elements, offset);
return(0);
=== modified file 'src/ioc/db/dbConvert.h'
--- src/ioc/db/dbConvert.h 2009-02-24 22:57:15 +0000
+++ src/ioc/db/dbConvert.h 2014-06-13 19:56:49 +0000
@@ -12,6 +12,7 @@
#define INCdbConverth
#include "dbFldTypes.h"
+#include "dbAddr.h"
#include "shareLib.h"
#ifdef __cplusplus
=== modified file 'src/ioc/db/test/Makefile'
--- src/ioc/db/test/Makefile 2012-07-17 19:33:31 +0000
+++ src/ioc/db/test/Makefile 2014-06-13 19:56:49 +0000
@@ -16,6 +16,11 @@
PROD_LIBS = xRec dbCore ca Com
+TESTPROD_HOST += testdbConvert
+testdbConvert_SRCS += testdbConvert.c
+testHarness_SRCS += testdbConvert.c
+TESTS += testdbConvert
TESTPROD_HOST += callbackTest
callbackTest_SRCS += callbackTest.c
testHarness_SRCS += callbackTest.c
@@ -56,6 +61,9 @@
TESTFILES += $(COMMON_DIR)/arrShorthandTest.dbd
TESTS += arrShorthandTest
+TESTPROD_HOST += benchdbConvert
+benchdbConvert_SRCS += benchdbConvert.c
# The testHarness runs all the test programs in a known working order.
testHarness_SRCS += epicsRunDbTests.c
=== added file 'src/ioc/db/test/benchdbConvert.c'
--- src/ioc/db/test/benchdbConvert.c 1970-01-01 00:00:00 +0000
+++ src/ioc/db/test/benchdbConvert.c 2014-06-13 19:56:49 +0000
@@ -0,0 +1,124 @@
+* Copyright (c) 2013 Brookhaven Science Assoc, as Operator of Brookhaven
+* National Laboratory.
+#include "string.h"
+#include "cantProceed.h"
+#include "dbConvert.h"
+#include "dbDefs.h"
+#include "epicsTime.h"
+#include "epicsMath.h"
+#include "epicsAssert.h"
+#include "epicsUnitTest.h"
+#include "testMain.h"
+typedef struct {
+ size_t nelem, niter;
+ short *output;
+ short *input;
+ GETCONVERTFUNC getter;
+ DBADDR addr;
+} testData;
+static long runRep(testData *D)
+ size_t i;
+ for(i=0; i<D->niter; i++) {
+ D->getter(&D->addr, D->output, D->nelem, D->nelem, 0);
+ return 0;
+static void runBench(size_t nelem, size_t niter, size_t nrep)
+ size_t i;
+ testData tdat;
+ double *reptimes;
+ testDiag("Using %lu element arrays.",(unsigned long)nelem);
+ testDiag("run %lu reps with %lu iterations each",
+ (unsigned long)nrep, (unsigned long)niter);
+ reptimes = callocMustSucceed(nrep, sizeof(*reptimes), "runBench");
+ tdat.output = callocMustSucceed(nelem, sizeof(*tdat.output), "runBench");
+ tdat.input = callocMustSucceed(nelem, sizeof(*tdat.input), "runBench");
+ tdat.nelem = nelem;
+ tdat.niter = niter;
+ tdat.getter = dbGetConvertRoutine[DBF_SHORT][DBF_SHORT];
+ memset(&tdat.addr, 0, sizeof(tdat.addr));
+ tdat.addr.field_type = DBF_SHORT;
+ tdat.addr.field_size = nelem*sizeof(*tdat.input);
+ tdat.addr.no_elements = nelem;
+ tdat.addr.pfield = (void*)tdat.input;
+ for(i=0; i<nelem; i++)
+ tdat.input[i] = (short)i;
+ for(i=0; i<nrep; i++)
+ epicsTimeStamp start, stop;
+ if(epicsTimeGetCurrent(&start)!=epicsTimeOK) {
+ testAbort("Failed to get timestamp");
+ goto done;
+ if(runRep(&tdat))
+ goto done;
+ if(epicsTimeGetCurrent(&stop)!=epicsTimeOK) {
+ goto done;
+ reptimes[i] = epicsTimeDiffInSeconds(&stop, &start);
+ testDiag("%lu bytes in %.03f ms. %.1f MB/s",
+ (unsigned long)(nelem*niter),
+ reptimes[i]*1e3,
+ (nelem*niter)/reptimes[i]/1e6);
+ double sum=0, sum2=0, mean;
+ for(i=0; i<nrep; i++) {
+ sum += reptimes[i];
+ sum2 += reptimes[i]*reptimes[i];
+ mean = sum/nrep;
+ testDiag("Final: %.04f ms +- %.05f ms. %.1f MB/s (for %lu elements)",
+ mean*1e3,
+ sqrt(sum2/nrep - mean*mean)*1e3,
+ (nelem*niter)/mean/1e6,
+ (unsigned long)nelem);
+done:
+ free(reptimes);
+ free(tdat.input);
+ free(tdat.output);
+MAIN(benchdbConvert)
+ testPlan(0);
+ runBench(1, 10000000, 10);
+ runBench(2, 5000000, 10);
+ runBench(10, 1000000, 10);
+ runBench(100, 100000, 10);
+ runBench(10000, 1000, 10);
+ runBench(100000, 100, 10);
+ runBench(1000000, 10, 10);
+ runBench(10000000, 1, 10);
+ return testDone();
=== modified file 'src/ioc/db/test/epicsRunDbTests.c'
--- src/ioc/db/test/epicsRunDbTests.c 2012-06-28 14:55:46 +0000
+++ src/ioc/db/test/epicsRunDbTests.c 2014-06-13 19:56:49 +0000
@@ -16,6 +16,7 @@
#include "epicsExit.h"
#include "dbmf.h"
+int testdbConvert(void);
int callbackTest(void);
int dbStateTest(void);
int testDbChannel(void);
@@ -26,6 +27,7 @@
testHarness();
+ runTest(testdbConvert);
runTest(callbackTest);
runTest(dbStateTest);
runTest(testDbChannel);
=== added file 'src/ioc/db/test/testdbConvert.c'
--- src/ioc/db/test/testdbConvert.c 1970-01-01 00:00:00 +0000
+++ src/ioc/db/test/testdbConvert.c 2014-06-13 19:56:49 +0000
@@ -0,0 +1,166 @@
+static const short s_input[] = {-1,0,1,2,3,4,5};
+static const size_t s_input_len = NELEMENTS(s_input);
+static void testBasicGet(void)
+ short *scratch;
+ DBADDR addr;
+ getter = dbGetConvertRoutine[DBF_SHORT][DBF_SHORT];
+ scratch = callocMustSucceed(s_input_len, sizeof(s_input), "testBasicGet");
+ memset(&addr, 0, sizeof(addr));
+ addr.field_type = DBF_SHORT;
+ addr.field_size = s_input_len*sizeof(*scratch);
+ addr.no_elements = s_input_len;
+ addr.pfield = (void*)s_input;
+ testDiag("Test dbGetConvertRoutine[DBF_SHORT][DBF_SHORT]");
+ testDiag("Copy out first element");
+ getter(&addr, scratch, 1, s_input_len, 0);
+ testOk1(scratch[0]==s_input[0]);
+ memset(scratch, 0x42, sizeof(s_input));
+ testDiag("Copy out entire array");
+ getter(&addr, scratch, s_input_len, s_input_len, 0);
+ testOk1(memcmp(scratch, s_input, sizeof(s_input))==0);
+ testDiag("Copy out partial array");
+ getter(&addr, scratch, 2, s_input_len, 0);
+ testOk1(memcmp(scratch, s_input, sizeof(short)*2)==0);
+ testOk1(scratch[2]==0x4242);
+ testDiag("Copy out w/ offset");
+ getter(&addr, scratch, 2, s_input_len, 1);
+ testOk1(memcmp(scratch, s_input+1, sizeof(short)*2)==0);
+ testDiag("Copy out end of array");
+ getter(&addr, scratch, 2, s_input_len, s_input_len-2);
+ testOk1(s_input_len-2 == 5);
+ testOk1(memcmp(scratch, s_input+5, sizeof(short)*2)==0);
+ testDiag("Copy out with wrap");
+ getter(&addr, scratch, 2, s_input_len, s_input_len-1);
+ testOk1(scratch[0] == s_input[6]);
+ testOk1(scratch[1] == s_input[0]);
+ testDiag("Crazy copy from out of bounds offset");
+ addr.pfield = (short*)(2*sizeof(short));
+ getter(&addr, scratch, s_input_len, s_input_len, (long)(s_input-2)/sizeof(short));
+ free(scratch);
+static void testBasicPut(void)
+ short *scratch;
+ DBADDR addr;
+ PUTCONVERTFUNC putter;
+ putter = dbPutConvertRoutine[DBF_SHORT][DBF_SHORT];
+ scratch = callocMustSucceed(s_input_len, sizeof(s_input), "testBasicPut");
+ addr.pfield = (void*)scratch;
+ testDiag("Test dbPutConvertRoutine[DBF_SHORT][DBF_SHORT]");
+ testDiag("Copy in first element");
+ putter(&addr, s_input, 1, s_input_len, 0);
+ testDiag("Copy in entire array");
+ putter(&addr, s_input, s_input_len, s_input_len, 0);
+MAIN(testdbConvert)
+ testPlan(16);
+ testBasicGet();
+ testBasicPut();
- Re: [Merge] lp:~epics-core/epics-base/dbConvert-memmove into lp:epics-base mdavidsaver
- Re: [Merge] lp:~epics-core/epics-base/dbConvert-memmove into lp:epics-base Andrew Johnson
- [Merge] lp:~epics-core/epics-base/dbConvert-memmove into lp:epics-base noreply
RE: auto-configure EPICS_CA_MAX_ARRAY_BYTES in catools/caget Hu, Yong
<2014>
Re: auto-configure EPICS_CA_MAX_ARRAY_BYTES in catools/caget Konrad, Martin
<2014>
