2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Build failed in Jenkins: epics-base-3.15-linux32 #2
To: [email protected]
Date: Fri, 7 Feb 2014 15:30:21 -0600 (CST)
See <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/2/>
Started by an SCM change
[EnvInject] - Loading node environment variables.
Building remotely on linux32-1 in workspace <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/>
$ bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/>
info result: bzr revision-info -d <https://jenkins.aps.anl.gov/job/epics-base-3.15-linux32/ws/> returned 0. Command output: "12464 [email protected]
" stderr: ""
[epics-base-3.15-linux32] $ bzr clean-tree --quiet --ignored --unknown --detritus --force
[epics-base-3.15-linux32] $ bzr pull --overwrite bzr+ssh://bazaar.launchpad.net/%2Bbranch/epics-base/3.15/
Permission denied (publickey).
bzr: ERROR: Connection closed: Unexpected end of message. Please check connectivity and permissions, and report a bug if problems persist.
ERROR: Failed to pull
Since BZR itself isn't crash safe, we'll clean the workspace so that on the next try we'll do a clean pull...
Jenkins build is back to normal : epics-base-3.15-linux32 #3 APS Jenkins
Prev: Jenkins build is back to normal : epics-base-3.14-linux32 #2 APS Jenkins
Next: Jenkins build is back to normal : epics-base-3.15-linux32 #3 APS Jenkins
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  <20142015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 16 May 2014 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
