2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base
Date: Wed, 04 Dec 2013 09:45:50 -0000
> On 12/03/2013 03:39 PM, mdavidsaver wrote:
> > On 12/03/2013 02:35 PM, Andrew Johnson wrote:
> >> For future reference: With almost 2**10 lines of diff this branch mixes
> > together (admittedly related) changes to several different subsystems,
> > ??? The merge proposal shows:
> > 961 lines (+337/-53) 21 files modified
> 961 ≈ 1024
> I'm just saying that the longer the diff is, the more reviewers will be
> put off looking at it. If the changes were split into smaller dependent
> branches, reviewing them might look like less work and could be done in
> smaller chunks (this was a human psychology comment, not a programming
> issue at all).
I was considering this, but did not find a useful subset of the changes that would have added a functionality that could be documented and tested for.
Which in my imagination would have led to rejection of each individual branch and you commenting that a single functionality should have been presented as a single branch instead of multiple dependent branches that don't add anything useful by itself. ;-)
Admittedly, I might have been able to split the callback related things off. But still with a high change of not being able to add the mandatory tests.
https://code.launchpad.net/~epics-core/epics-base/ioc-shutdown/+merge/190512
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 04 Dec 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
