Hi Dirk,
On 11/27/2013 07:09 AM, Dirk Zimoch wrote:
I have added pp(TRUE) to some fields, so that the behavior is similar to
the calc record. The following fields are affected:
sel: SELM, SELN
seq: SELM, SELN, DO1, DO2, ... DOA
I don't want to make this kind of change to record behaviour in a
bug-fix release (3.14.12.4), although I will consider them for the 3.15
branch.
The seq record only has one field marked as pp(TRUE), the VAL field, and
the prompt text for that field is "Used to trigger", so I suspect the
implicit pp(FALSE) setting on the other fields was a deliberate design
decision by the author. I'm currently inclined to change the sel record
but not the seq, but would appreciate comments from anyone else about
this idea (which makes the two behave differently so I'm not really
convinced that's right either).
The disadvantage of making fields pp(TRUE) is that a client then has no
choice about processing the record, whereas for a pp(FALSE) field a
client can always follow up with a put to the PROC field (there's a
feature which display managers haven't implemented yet AFAIK). A
database designer can also insert an ao record in front of the relevant
fields of the seq record with a PP or NPP output link to change the
behaviour one way or the other, so there are workarounds to a field
having the wrong pp() setting.
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
Re: [Merge] lp:~epics-core/epics-base/parallel-cbthreads-2 into lp:epics-base mdavidsaver
Re: [Merge] lp:~epics-core/epics-base/ioc-shutdown into lp:epics-base Andrew Johnson
<2013>
[Merge] lp:~epics-core/epics-base/postdbrprop into lp:epics-base noreply
<2013>
