2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Fri, 22 Nov 2013 00:01:03 -0000
Jeff, if you've decided to abandon this idea as a result of this discussion, could you delete the merge proposal or set its status to Rejected please, just so we know. -- Thanks.
https://code.launchpad.net/~johill-lanl/epics-base/epics-base-enclosure-of/+merge/196010
Your team EPICS Core Developers is subscribed to branch lp:epics-base.
[Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base Jeff Hill
Prev: Re: [Merge] lp:~johill-lanl/epics-base/epics-base-enclosure-of into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  <20132014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Base 3.14.12.4-pre1 available for testing Andrew Johnson
ANJ, 30 Nov 2013 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
