Hi Jeff,
On 11/20/2013 10:32 AM, Hill, Jeff wrote:
I notice that when building the R3.15 tip a "make clean" doesn't
actually remove any (most of) the files.
This is definitely another issue with your setup, here's the start of my
output from make clean:
D:\epics\mirror-3.15>make clean
make -C ./configure clean
make[1]: Entering directory `D:/epics/mirror-3.15/configure'
perl -CSD -MExtUtils::Command -e rm_rf O.win32-x86 O.Common
make[1]: Leaving directory `D:/epics/mirror-3.15/configure'
make -C ./src clean
make[1]: Entering directory `D:/epics/mirror-3.15/src'
make -C ./tools clean
make[2]: Entering directory `D:/epics/mirror-3.15/src/tools'
make[2]: Leaving directory `D:/epics/mirror-3.15/src/tools'
make -C tools/test clean
make[2]: Entering directory `D:/epics/mirror-3.15/src/tools/test'
make[2]: Leaving directory `D:/epics/mirror-3.15/src/tools/test'
make -C template/base clean
make[2]: Entering directory `D:/epics/mirror-3.15/src/template/base'
make[2]: Leaving directory `D:/epics/mirror-3.15/src/template/base'
make -C template/ext clean
make[2]: Entering directory `D:/epics/mirror-3.15/src/template/ext'
make[2]: Leaving directory `D:/epics/mirror-3.15/src/template/ext'
make -C ./libCom clean
make[2]: Entering directory `D:/epics/mirror-3.15/src/libCom'
make[2]: Leaving directory `D:/epics/mirror-3.15/src/libCom'
It makes no difference here whether the tree is initially populated or
clean, I tried both.
You need to investigate why the first sub-command that your make runs is
not a clean but an install in the sub-directory:
C:\hill\epicsInBazaar\R3.15-mirror-II>make clean
C:/Program Files (x86)/GnuWin32/bin/make -C ./configure install
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- RE: make clean builds the install target on R3.15? Hill, Jeff
- make clean builds the install target on R3.15? Hill, Jeff
<2013>
<2013>
