Andrew,
On 11/06/2013 11:03 AM, Andrew Johnson wrote:
This will also need release notes, modifications to the AppDevGuide to
document the prop() attribute,
It is no problem to write a blurb for the release notes. However, I'm
not that familiar with the AppDevGuide (it has never guided me). Do any
sections other than 6.7.2 (Field Definitions Rules) need to be changed?
http://www.aps.anl.gov/epics/base/R3-14/12-docs/AppDevGuide/node7.html#SECTION00770000000000000000
and checking with vdct to see if it
accepts this attribute in a DBD file.
vdct 2.6.1278 seems to have no problems.
On this subject. Your perl DBD parser errors out when given unknown
field attributes while dbStatic ignores them. Can the perl parser be
made to do the same (or at least change this to a warning)?
Michael
- posting DBE_PROPERTY Michael Davidsaver
- Re: posting DBE_PROPERTY Andrew Johnson
Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Jeff Hill
Re: [Merge] lp:~johill-lanl/epics-base/ca-ref-man-maint into lp:epics-base Andrew Johnson
<2013>
[Merge] lp:~epics-core/epics-base/3.15_libcom_from_cvs_trunk into lp:epics-base Jeff Hill
<2013>
