Hi Ben,
On 08/22/2013 09:00 AM, Benjamin Franksen wrote:
We recently compiled msi (a patched version but that is not the point here)
with R3.14.12.2 and stumbled over the "recursive" and "undefined" keywords
that the macLib seems to insert when expanding, respectively, recursive or
undefined macros.
They're not really keywords as such because they are not specifically
recognized in the input text. The scoped macro syntax allows you to
declare or define sub-macros after the name and/or default value inside
the macro body, and I made use of that syntax to add those two words as
markers. The strings ",recursive" or ",undefined" are appended to the
macro body when those conditions are detected during expansion; they
will ignored if the generated text is subsequently passed through macLib
again with the macro properly defined (macLib parses them as a sub-macro
that just hasn't been given a value).
I remembered this being talked about on tech-talk at one
time but I could not find the thread in the archives. So I tried to find
documentation about this somewhere. I looked into the Application Developer's
Guide, the release notes, and the file macLibREADME in the sources, all to no
avail. We even looked at the changeset comments using the bazaar web interface
(3.14 branch). It appears this change was introduced along with the
introduction of scoping in the macLib, but the comment did not say so.
Correct, mea culpa (obviously!).
Anyway, the main intent of this message is not to complain, but rather to
(politely) request that some documentation for the macLib is added somewhere,
ideally in the Application Developer's Guide (which already contains a section
on the macLib but only lists the exported procedures). The macLibREADME is
probably a good starting point, but it would need to be updated to include the
latest changes.
The documentation needs to be moved into the libCom chapter of the
Application Developers Guide. There is a Launchpad bug against the
guide https://bugs.launchpad.net/epics-appdev/+bug/641365 which says
exactly this, although it didn't go into detail about what needs to be
added until now.
I'll see what I can do. Maybe we could move all EPICS development to
Mars where the day is 40 minutes longer than on Earth...
- Andrew
Advertising may be described as the science of arresting the human
intelligence long enough to get money from it. -- Stephen Leacock
- Re: macLib semantics should be documented somewhere Benjamin Franksen
- macLib semantics should be documented somewhere Benjamin Franksen
[Bug 641365] Re: Incorporate macLibREADME text into 19.16 Andrew Johnson
<2013>
<2013>
