For some time now I've had the idea that it would be useful to have API
for executing a list of get/put DB operations. What would make this
most useful, and most difficult to implement, would be an option to make
such batch operations atomic (wrt. record locking). I've done some
investigations into how this might be implemented, and I think I have a
clear strategy. However, there are two questions I need to get answered
before I can proceed.
1) Can the three functions from dbLock.h mentioned below be removed
(replaced)?
2) Is the proposed API for batch operations acceptable?
The primary impediment I see to implementing atomic locking of an
arbitrary list of records is the current lockset API. In particular the
following function definitions:
void dbLockSetGblLock(void);
void dbLockSetGblUnlock(void);
void dbLockSetRecordLock(struct dbCommon *precord);
The way this API is defined requires that dbLockSetRecordLock() be
called for each record sequentially. This is helpful if the records to
be locked ahead of time is not known. Unfortunately it uses a global
lock to avoid deadlock conditions, which also serializes all operations.
The only way I can think of to avoid the global lock would be to allow
the operation to fail if it would cause a deadlock condition. This is
less than desirable since these failures would not be predictable.
So I am left wanting to replace these functions with something like:
struct lockNode {
ELLNODE node;
dbCommon *precord;
void dbScanLockMany(ELLLIST *lockNodes);
void dbScanUnlockMany(ELLLIST *lockNodes);
So far I have seen the dbLockSet* functions used only within Base,
specifically dbPutFieldLink() in dbAccess.c during modification of a
link field.
Enabling dbPutFieldLink() to use this new API would require parsing the
new link field value before locking any records. The goal is to
determine in advance if the a new DB link will (or might be) created. I
think all the necessary context information can be read w/o locking the
record. This would give a list of all the records which need to be
locked to complete the entire operation, allowing the new locking API to
be used.
Now the implementation issue is avoiding deadlocks. The best strategy
I've come up with so far is to assign all locksets to a global order.
The simplest way is to use a pointer address. Each operation would
start by sorting the list of records, and always lock from lowest to
highest.
Of course lock set re-computations could change the ordering. My plan
here is to reference count the lockSets. So a dbFieldOperations() call
will first take a reference to all the necessary locksets while holding
a global lock. Then it will lock all of the locksets. Finally it will
check to see that the association between records and locksets hasn't
changed, and retry if it has.
The next question is how to define the DB batch operation API. My
current thoughts are:
struct DBOp {
ELLNODE node;
unsigned int op; // 0=get, 1=put
void *userbuf;
long *options;
epicsUInt32 nRequest;
void *pflin; // get only
DBOp* allocDBOp(void);
void freeDBOp(DBOp*);
#define DBOP_FAST 0 // meaning low latency
#define DBOP_ATOMIC 1
int dbFieldOperations(ELLLIST *dbops, unsigned long flags);
The alloc and free functions would serve to enable a free-list, and also
to allow parts of the structure to be hidden (including the lockNode
struct). The DBOP_* macros would be used to give the 'flags' argument.
I've done some prototypes which worked (didn't deadlock), however I have
some concerns about the time needed to acquire several locks, and the
contention this would cause. I think the worst case multi-lock latency
for a single dbScanLockMany() call would be the sum of the worst case
latencies of each individual lock from other sources (plain
dbScanLock). This would then be multiplied by the number of concurrent,
overlapping, dbScanLockMany() calls.
In cases involving a few locksets this would likely not be significant,
but in complex situations could be quite large. So perhaps some
requests could be restricted?
Does anyone has thoughts on better (or other) ways to accomplish this?
- Re: New API for batched dbGet/dbPut Michael Davidsaver
[Merge] lp:~epics-core/epics-base/array-opt into lp:epics-base mdavidsaver
Proposal to add site-specific TOP_RULES Benjamin Franksen
<2013>
[Merge] lp:~epics-core/epics-base/array-opt into lp:epics-base noreply
<2013>
