mdavidsaver has proposed merging lp:~epics-core/epics-base/array-opt into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/array-opt/+merge/149396
Allow device support code to safely replace BPTR for waveform, aai, and aao recordtypes. This avoids a copy when moving array data into and out of a record.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/array-opt into lp:epics-base.
=== modified file 'src/ioc/db/dbAccess.c'
--- src/ioc/db/dbAccess.c 2012-10-29 06:20:56 +0000
+++ src/ioc/db/dbAccess.c 2013-02-19 20:35:24 +0000
@@ -780,6 +780,7 @@
void *pbuffer, long *options, long *nRequest, void *pflin)
char *pbuf = pbuffer;
+ void *pfieldsave;
db_field_log *pfl = (db_field_log *)pflin;
short field_type;
long no_elements;
@@ -815,6 +816,13 @@
return S_db_badDbrtype;
+ /* For array field, the rset function
+ * get_array_info() is allowed to modify
+ * paddr->pfield. So we store the original
+ * value and restore it later.
+ pfieldsave = paddr->pfield;
/* check for array */
if ((!pfl || pfl->type == dbfl_type_rec) &&
paddr->special == SPC_DBADDR &&
@@ -860,7 +868,8 @@
sprintf(message, "dbGet: Missing conversion for [%d][%d]\n",
field_type, dbrType);
recGblDbaddrError(S_db_badDbrtype, paddr, message);
- return S_db_badDbrtype;
+ status = S_db_badDbrtype;
+ goto done;
/* convert database field and place it in the buffer */
if (n <= 0) {
@@ -880,6 +889,8 @@
status = convert(&localAddr, pbuf, n, no_elements, offset);
+done:
+ paddr->pfield = pfieldsave;
return status;
=== modified file 'src/std/filters/arr.c'
--- src/std/filters/arr.c 2012-07-17 19:33:31 +0000
+++ src/std/filters/arr.c 2013-02-19 20:35:24 +0000
@@ -104,7 +104,9 @@
if (chan->addr.special == SPC_DBADDR &&
nSource > 1 &&
(prset = dbGetRset(&chan->addr)) &&
- prset->get_array_info) {
+ prset->get_array_info)
+ void *pfieldsave = chan->addr.pfield;
prec = dbChannelRecord(chan);
dbScanLock(prec);
prset->get_array_info(&chan->addr, &nSource, &offset);
@@ -126,6 +128,7 @@
pfl->u.r.field = pdst;
dbScanUnlock(prec);
+ chan->addr.pfield = pfieldsave;
/* Extract from buffer */
=== modified file 'src/std/rec/aaiRecord.c'
--- src/std/rec/aaiRecord.c 2012-01-21 21:20:11 +0000
+++ src/std/rec/aaiRecord.c 2013-02-19 20:35:24 +0000
@@ -183,7 +183,6 @@
aaiRecord *prec = (aaiRecord *)paddr->precord;
- paddr->pfield = prec->bptr;
paddr->no_elements = prec->nelm;
paddr->field_type = prec->ftvl;
paddr->field_size = dbValueSize(prec->ftvl);
@@ -195,6 +194,7 @@
+ paddr->pfield = prec->bptr;
*no_elements = prec->nord;
*offset = 0;
return 0;
@@ -308,7 +308,7 @@
if (monitor_mask)
- db_post_events(prec, prec->bptr, monitor_mask);
+ db_post_events(prec, (void*)&prec->val, monitor_mask);
static long readValue(aaiRecord *prec)
=== modified file 'src/std/rec/aaoRecord.c'
--- src/std/rec/aaoRecord.c 2012-01-21 21:20:11 +0000
+++ src/std/rec/aaoRecord.c 2013-02-19 20:35:24 +0000
@@ -183,7 +183,6 @@
aaoRecord *prec = (aaoRecord *)paddr->precord;
@@ -195,6 +194,7 @@
*offset = 0;
return 0;
@@ -308,7 +308,7 @@
if (monitor_mask)
static long writeValue(aaoRecord *prec)
=== modified file 'src/std/rec/waveformRecord.c'
--- src/std/rec/waveformRecord.c 2012-07-07 20:54:31 +0000
+++ src/std/rec/waveformRecord.c 2013-02-19 20:35:24 +0000
@@ -163,7 +163,6 @@
waveformRecord *prec = (waveformRecord *) paddr->precord;
@@ -176,6 +175,7 @@
*offset = 0;
@@ -300,7 +300,7 @@
if (monitor_mask) {
- Re: [Merge] lp:~epics-core/epics-base/array-opt into lp:epics-base Andrew Johnson
- [Merge] lp:~epics-core/epics-base/array-opt into lp:epics-base noreply
Re: mbboDirect changes Andrew Johnson
New API for batched dbGet/dbPut Michael Davidsaver
<2013>
<2013>
