Andrew Johnson has proposed merging lp:~epics-core/epics-base/printf-record into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~epics-core/epics-base/printf-record/+merge/139098
This branch adds three new record types and associated device support to Base:
* printf: A string conversion record, plus device support for Soft Channel, Async Soft Channel and stdio device types.
* lsi: A long string input record, plus device support for Soft Channel input.
* lso: A long string output record, plus device support for Soft Channel, Async Soft Channel and stdio device types.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/printf-record into lp:epics-base.
=== modified file 'src/ioc/db/Makefile'
--- src/ioc/db/Makefile 2012-06-21 20:27:32 +0000
+++ src/ioc/db/Makefile 2012-12-10 21:21:25 +0000
@@ -47,6 +47,7 @@
menuGlobal_DBD += menuIvoa.dbd
menuGlobal_DBD += menuOmsl.dbd
menuGlobal_DBD += menuPini.dbd
+menuGlobal_DBD += menuPost.dbd
menuGlobal_DBD += menuPriority.dbd
menuGlobal_DBD += menuScan.dbd
menuGlobal_DBD += menuYesNo.dbd
=== modified file 'src/ioc/db/dbAccess.c'
--- src/ioc/db/dbAccess.c 2012-10-29 06:20:56 +0000
+++ src/ioc/db/dbAccess.c 2012-12-10 21:21:25 +0000
@@ -583,10 +583,8 @@
DBENTRY dbEntry;
dbFldDes *pflddes;
- struct rset *prset;
long status = 0;
- long no_elements = 1;
- short dbfType, dbrType, field_size;
+ short dbfType;
if (!pname || !*pname || !pdbbase)
return S_db_notFound;
@@ -601,48 +599,49 @@
status = dbGetAttributePart(&dbEntry, &pname);
if (status) goto finish;
+ pflddes = dbEntry.pflddes;
+ dbfType = pflddes->field_type;
paddr->precord = dbEntry.precnode->precord;
paddr->pfield = dbEntry.pfield;
- pflddes = dbEntry.pflddes;
- dbfType = pflddes->field_type;
- dbrType = mapDBFToDBR[dbfType];
- field_size = pflddes->size;
+ paddr->pfldDes = pflddes;
+ paddr->no_elements = 1;
+ paddr->field_type = dbfType;
+ paddr->field_size = pflddes->size;
+ paddr->special = pflddes->special;
+ paddr->dbr_field_type = mapDBFToDBR[dbfType];
+ if (paddr->special == SPC_DBADDR) {
+ struct rset *prset = dbGetRset(paddr);
+ /* Let record type modify paddr */
+ if (prset && prset->cvt_dbaddr) {
+ status = prset->cvt_dbaddr(paddr);
+ if (status)
+ goto finish;
+ dbfType = paddr->field_type;
+ /* Handle field modifiers */
if (*pname++ == '$') {
/* Some field types can be accessed as char arrays */
if (dbfType == DBF_STRING) {
- dbfType = DBF_CHAR;
- dbrType = DBR_CHAR;
- no_elements = field_size;
- field_size = 1;
+ paddr->no_elements = paddr->field_size;
+ paddr->field_type = DBF_CHAR;
+ paddr->field_size = 1;
+ paddr->dbr_field_type = DBR_CHAR;
} else if (dbfType >= DBF_INLINK && dbfType <= DBF_FWDLINK) {
/* Clients see a char array, but keep original dbfType */
- no_elements = PVNAME_STRINGSZ + 12;
- field_size = 1;
+ paddr->no_elements = PVNAME_STRINGSZ + 12;
} else {
status = S_dbLib_fieldNotFound;
goto finish;
- paddr->pfldDes = pflddes;
- paddr->field_type = dbfType;
- paddr->dbr_field_type = dbrType;
- paddr->field_size = field_size;
- paddr->special = pflddes->special;
- paddr->no_elements = no_elements;
- if ((paddr->special == SPC_DBADDR) &&
- (prset = dbGetRset(paddr)) &&
- prset->cvt_dbaddr)
- /* cvt_dbaddr routine may change any of these elements of paddr:
- * pfield, no_elements, element_offset, field_type,
- * dbr_field_type, field_size, and/or special.
- status = prset->cvt_dbaddr(paddr);
finish:
dbFinishEntry(&dbEntry);
return status;
@@ -817,7 +816,7 @@
/* check for array */
if ((!pfl || pfl->type == dbfl_type_rec) &&
- paddr->special == SPC_DBADDR &&
+ paddr->pfldDes->special == SPC_DBADDR &&
no_elements > 1 &&
prset->get_array_info) {
@@ -1171,7 +1170,7 @@
long offset = 0;
- if (paddr->special == SPC_DBADDR &&
+ if (paddr->pfldDes->special == SPC_DBADDR &&
prset && prset->get_array_info) {
long dummy;
@@ -1184,7 +1183,7 @@
/* update array info */
if (!status &&
prset && prset->put_array_info) {
status = prset->put_array_info(paddr, nRequest);
=== modified file 'src/ioc/db/dbLink.c'
--- src/ioc/db/dbLink.c 2012-07-07 20:54:31 +0000
+++ src/ioc/db/dbLink.c 2012-12-10 21:21:25 +0000
@@ -649,3 +649,62 @@
+/* Helper functions for long string support */
+long dbLoadLinkLS(struct link *plink, char *pbuffer, epicsUInt32 size,
+ epicsUInt32 *plen)
+ if (plink->type == CONSTANT &&
+ plink->value.constantStr) {
+ strncpy(pbuffer, plink->value.constantStr, --size);
+ pbuffer[size] = 0;
+ *plen = strlen(pbuffer) + 1;
+ return 0;
+ return S_db_notFound;
+long dbGetLinkLS(struct link *plink, char *pbuffer, epicsUInt32 size,
+ int dtyp = dbGetLinkDBFtype(plink);
+ long len = size;
+ long status;
+ if (dtyp < 0) /* Not connected */
+ return 0;
+ if (dtyp == DBR_CHAR || dtyp == DBF_UCHAR) {
+ status = dbGetLink(plink, dtyp, pbuffer, 0, &len);
+ else if (size >= MAX_STRING_SIZE)
+ status = dbGetLink(plink, DBR_STRING, pbuffer, 0, 0);
+ else {
+ /* pbuffer is too small to fetch using DBR_STRING */
+ char tmp[MAX_STRING_SIZE];
+ status = dbGetLink(plink, DBR_STRING, tmp, 0, 0);
+ if (!status)
+ strncpy(pbuffer, tmp, len - 1);
+ if (!status) {
+ pbuffer[--len] = 0;
+ return status;
+long dbPutLinkLS(struct link *plink, char *pbuffer, epicsUInt32 len)
+ if (dtyp < 0)
+ return 0; /* Not connected */
+ return dbPutLink(plink, dtyp, pbuffer, len);
+ return dbPutLink(plink, DBR_STRING, pbuffer, 1);
=== modified file 'src/ioc/db/dbLink.h'
--- src/ioc/db/dbLink.h 2012-08-08 18:38:21 +0000
+++ src/ioc/db/dbLink.h 2012-12-10 21:21:25 +0000
@@ -81,6 +81,13 @@
const void *pbuffer, long nRequest);
epicsShareFunc void dbScanFwdLink(struct link *plink);
+epicsShareFunc long dbLoadLinkLS(struct link *plink, char *pbuffer,
+ epicsUInt32 size, epicsUInt32 *plen);
+epicsShareFunc long dbGetLinkLS(struct link *plink, char *pbuffer,
+ epicsUInt32 buffer_size, epicsUInt32 *plen);
+epicsShareFunc long dbPutLinkLS(struct link *plink, char *pbuffer,
+ epicsUInt32 len);
#ifdef __cplusplus
#endif
=== added file 'src/ioc/db/menuPost.dbd'
--- src/ioc/db/menuPost.dbd 1970-01-01 00:00:00 +0000
+++ src/ioc/db/menuPost.dbd 2012-12-10 21:21:25 +0000
@@ -0,0 +1,11 @@
+# Copyright (c) 2012 UChicago Argonne LLC, as Operator of Argonne
+# National Laboratory.
+# EPICS BASE is distributed subject to a Software License Agreement found
+# in file LICENSE that is included with this distribution.
+menu(menuPost) {
+ choice(menuPost_OnChange, "On Change")
+ choice(menuPost_Always, "Always")
=== modified file 'src/std/dev/Makefile'
--- src/std/dev/Makefile 2012-07-11 23:07:23 +0000
+++ src/std/dev/Makefile 2012-12-10 21:21:25 +0000
@@ -30,6 +30,8 @@
dbRecStd_SRCS += devHistogramSoft.c
dbRecStd_SRCS += devLiSoft.c
dbRecStd_SRCS += devLoSoft.c
+dbRecStd_SRCS += devLsiSoft.c
+dbRecStd_SRCS += devLsoSoft.c
dbRecStd_SRCS += devMbbiDirectSoft.c
dbRecStd_SRCS += devMbbiDirectSoftRaw.c
dbRecStd_SRCS += devMbbiSoft.c
@@ -38,6 +40,7 @@
dbRecStd_SRCS += devMbboDirectSoftRaw.c
dbRecStd_SRCS += devMbboSoft.c
dbRecStd_SRCS += devMbboSoftRaw.c
+dbRecStd_SRCS += devPrintfSoft.c
dbRecStd_SRCS += devSASoft.c
dbRecStd_SRCS += devSiSoft.c
dbRecStd_SRCS += devSoSoft.c
@@ -55,12 +58,14 @@
dbRecStd_SRCS += devBoSoftCallback.c
dbRecStd_SRCS += devCalcoutSoftCallback.c
dbRecStd_SRCS += devLoSoftCallback.c
+dbRecStd_SRCS += devLsoSoftCallback.c
dbRecStd_SRCS += devMbboSoftCallback.c
dbRecStd_SRCS += devMbboDirectSoftCallback.c
+dbRecStd_SRCS += devPrintfSoftCallback.c
dbRecStd_SRCS += devSoSoftCallback.c
dbRecStd_SRCS += devTimestamp.c
-dbRecStd_SRCS += devSoStdio.c
+dbRecStd_SRCS += devStdio.c
dbRecStd_SRCS += asSubRecordFunctions.c
=== added file 'src/std/dev/devLsiSoft.c'
--- src/std/dev/devLsiSoft.c 1970-01-01 00:00:00 +0000
+++ src/std/dev/devLsiSoft.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,42 @@
+* Copyright (c) 2012 UChicago Argonne LLC, as Operator of Argonne
+* National Laboratory.
+* EPICS BASE is distributed subject to a Software License Agreement found
+* in file LICENSE that is included with this distribution.
+/* Long String Input soft device support
+ * Author: Andrew Johnson
+ * Date: 2012-11-28
+#include "dbAccess.h"
+#include "epicsTime.h"
+#include "link.h"
+#include "lsiRecord.h"
+#include "epicsExport.h"
+static long init_record(lsiRecord *prec)
+ dbLoadLinkLS(&prec->inp, prec->val, prec->sizv, &prec->len);
+ return 0;
+static long read_string(lsiRecord *prec)
+ long status = dbGetLinkLS(&prec->inp, prec->val, prec->sizv, &prec->len);
+ if (!status &&
+ prec->tsel.type == CONSTANT &&
+ prec->tse == epicsTimeEventDeviceTime)
+ dbGetTimeStamp(&prec->inp, &prec->time);
+ return status;
+lsidset devLsiSoft = {
+ 5, NULL, NULL, init_record, NULL, read_string
+epicsExportAddress(dset, devLsiSoft);
=== added file 'src/std/dev/devLsoSoft.c'
--- src/std/dev/devLsoSoft.c 1970-01-01 00:00:00 +0000
+++ src/std/dev/devLsoSoft.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,26 @@
+/* Long String Output soft device support
+ * Date: 2012-11-29
+#include "lsoRecord.h"
+static long write_string(lsoRecord *prec)
+ return dbPutLinkLS(&prec->out, prec->val, prec->len);
+lsodset devLsoSoft = {
+ 5, NULL, NULL, NULL, NULL, write_string
+epicsExportAddress(dset, devLsoSoft);
=== added file 'src/std/dev/devLsoSoftCallback.c'
--- src/std/dev/devLsoSoftCallback.c 1970-01-01 00:00:00 +0000
+++ src/std/dev/devLsoSoftCallback.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,51 @@
+/* $Revision-Id$ */
+ * Date: 30 Nov 2012
+#include "alarm.h"
+#include "recGbl.h"
+ struct link *plink = &prec->out;
+ long len = prec->len;
+ long status;
+ if (prec->pact || dtyp < 0)
+ return 0;
+ if (dtyp != DBR_CHAR && dtyp != DBF_UCHAR) {
+ dtyp = DBR_STRING;
+ len = 1;
+ if (plink->type != CA_LINK)
+ return dbPutLink(plink, dtyp, prec->val, len);
+ status = dbCaPutLinkCallback(plink, dtyp, prec->val, len,
+ dbCaCallbackProcess, plink);
+ if (status) {
+ recGblSetSevr(prec, LINK_ALARM, INVALID_ALARM);
+ return status;
+ prec->pact = TRUE;
+ return 0;
+lsodset devLsoSoftCallback = {
+epicsExportAddress(dset, devLsoSoftCallback);
=== added file 'src/std/dev/devPrintfSoft.c'
--- src/std/dev/devPrintfSoft.c 1970-01-01 00:00:00 +0000
+++ src/std/dev/devPrintfSoft.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,26 @@
+ * Date: 28 Sept 2012
+#include "printfRecord.h"
+static long write_string(printfRecord *prec)
+printfdset devPrintfSoft = {
+epicsExportAddress(dset, devPrintfSoft);
=== added file 'src/std/dev/devPrintfSoftCallback.c'
--- src/std/dev/devPrintfSoftCallback.c 1970-01-01 00:00:00 +0000
+++ src/std/dev/devPrintfSoftCallback.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,51 @@
+#include "alarm.h"
+ long status;
+ return 0;
+ len = 1;
+ if (status) {
+ return status;
+ return 0;
+printfdset devPrintfSoftCallback = {
+epicsExportAddress(dset, devPrintfSoftCallback);
=== removed file 'src/std/dev/devSoStdio.c'
--- src/std/dev/devSoStdio.c 2012-07-18 21:45:23 +0000
+++ src/std/dev/devSoStdio.c 1970-01-01 00:00:00 +0000
@@ -1,108 +0,0 @@
-* Copyright (c) 2008 UChicago Argonne LLC, as Operator of Argonne
-* National Laboratory.
-* EPICS BASE is distributed subject to a Software License Agreement found
-* in file LICENSE that is included with this distribution.
-/* $Revision-Id$ */
-#include <stdio.h>
-#include <string.h>
-#include "dbCommon.h"
-#include "devSup.h"
-#include "errlog.h"
-#include "recGbl.h"
-#include "recSup.h"
-#include "stringoutRecord.h"
-#include "epicsExport.h"
-typedef int (*PRINTFFUNC)(const char *fmt, ...);
-static int stderrPrintf(const char *fmt, ...);
-static int logPrintf(const char *fmt, ...);
-static struct outStream {
- const char *name;
- PRINTFFUNC print;
-} outStreams[] = {
- {"stdout", printf},
- {"stderr", stderrPrintf},
- {"errlog", logPrintf},
- {NULL, NULL}
-static int stderrPrintf(const char *fmt, ...) {
- va_list pvar;
- int retval;
- va_start(pvar, fmt);
- retval = vfprintf(stderr, fmt, pvar);
- va_end (pvar);
- return retval;
-static int logPrintf(const char *fmt, ...) {
- va_list pvar;
- int retval;
- retval = errlogVprintf(fmt, pvar);
- va_end (pvar);
- return retval;
-static long add(dbCommon *pcommon) {
- stringoutRecord *prec = (stringoutRecord *) pcommon;
- struct outStream *pstream;
- if (prec->out.type != INST_IO)
- return S_dev_badOutType;
- for (pstream = outStreams; pstream->name; ++pstream) {
- if (strcmp(prec->out.value.instio.string, pstream->name) == 0) {
- prec->dpvt = pstream;
- return 0;
- prec->dpvt = NULL;
- return -1;
-static long del(dbCommon *pcommon) {
- return 0;
-static struct dsxt dsxtSoStdio = {
- add, del
-static long init(int pass)
- if (pass == 0) devExtend(&dsxtSoStdio);
- return 0;
-static long write_string(stringoutRecord *prec)
- struct outStream *pstream = (struct outStream *)prec->dpvt;
- if (pstream)
- pstream->print("%s\n", prec->val);
- return 0;
-/* Create the dset for devSoStdio */
-static struct {
- dset common;
- DEVSUPFUN write;
-} devSoStdio = {
- {5, NULL, init, NULL, NULL}, write_string
-epicsExportAddress(dset, devSoStdio);
=== modified file 'src/std/dev/devSoft.dbd'
--- src/std/dev/devSoft.dbd 2012-07-11 23:07:23 +0000
+++ src/std/dev/devSoft.dbd 2012-12-10 21:21:25 +0000
@@ -9,10 +9,13 @@
device(histogram,CONSTANT,devHistogramSoft,"Soft Channel")
device(longin,CONSTANT,devLiSoft,"Soft Channel")
device(longout,CONSTANT,devLoSoft,"Soft Channel")
+device(lsi,CONSTANT,devLsiSoft,"Soft Channel")
+device(lso,CONSTANT,devLsoSoft,"Soft Channel")
device(mbbi,CONSTANT,devMbbiSoft,"Soft Channel")
device(mbbiDirect,CONSTANT,devMbbiDirectSoft,"Soft Channel")
device(mbbo,CONSTANT,devMbboSoft,"Soft Channel")
device(mbboDirect,CONSTANT,devMbboDirectSoft,"Soft Channel")
+device(printf,CONSTANT,devPrintfSoft,"Soft Channel")
device(stringin,CONSTANT,devSiSoft,"Soft Channel")
device(stringout,CONSTANT,devSoSoft,"Soft Channel")
device(subArray,CONSTANT,devSASoft,"Soft Channel")
@@ -34,10 +37,12 @@
device(calcout,CONSTANT,devCalcoutSoftCallback,"Async Soft Channel")
device(longin,CONSTANT,devLiSoftCallback,"Async Soft Channel")
device(longout,CONSTANT,devLoSoftCallback,"Async Soft Channel")
+device(lso,CONSTANT,devLsoSoftCallback,"Async Soft Channel")
device(mbbi,CONSTANT,devMbbiSoftCallback,"Async Soft Channel")
device(mbbiDirect,CONSTANT,devMbbiDirectSoftCallback,"Async Soft Channel")
device(mbbo,CONSTANT,devMbboSoftCallback,"Async Soft Channel")
device(mbboDirect,CONSTANT,devMbboDirectSoftCallback,"Async Soft Channel")
+device(printf,CONSTANT,devPrintfSoftCallback,"Async Soft Channel")
device(stringin,CONSTANT,devSiSoftCallback,"Async Soft Channel")
device(stringout,CONSTANT,devSoSoftCallback,"Async Soft Channel")
@@ -49,6 +54,8 @@
device(longin, INST_IO,devLiGeneralTime,"General Time")
device(stringin,INST_IO,devSiGeneralTime,"General Time")
+device(lso,INST_IO,devLsoStdio,"stdio")
+device(printf,INST_IO,devPrintfStdio,"stdio")
device(stringout,INST_IO,devSoStdio,"stdio")
device(bi, INST_IO, devBiDbState, "Db State")
=== added file 'src/std/dev/devStdio.c'
--- src/std/dev/devStdio.c 1970-01-01 00:00:00 +0000
+++ src/std/dev/devStdio.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,212 @@
+* Copyright (c) 2008 UChicago Argonne LLC, as Operator of Argonne
+#include <stdio.h>
+#include <string.h>
+#include "dbCommon.h"
+#include "devSup.h"
+#include "errlog.h"
+#include "recSup.h"
+#include "stringoutRecord.h"
+typedef int (*PRINTFFUNC)(const char *fmt, ...);
+static int stderrPrintf(const char *fmt, ...);
+static int logPrintf(const char *fmt, ...);
+static struct outStream {
+ const char *name;
+ PRINTFFUNC print;
+} outStreams[] = {
+ {"stdout", printf},
+ {"stderr", stderrPrintf},
+ {"errlog", logPrintf},
+ {NULL, NULL}
+static int stderrPrintf(const char *fmt, ...) {
+ va_list pvar;
+ int retval;
+ va_start(pvar, fmt);
+ retval = vfprintf(stderr, fmt, pvar);
+ va_end (pvar);
+ return retval;
+static int logPrintf(const char *fmt, ...) {
+ va_list pvar;
+ int retval;
+ retval = errlogVprintf(fmt, pvar);
+ va_end (pvar);
+ return retval;
+/* lso device support */
+static long add_lso(dbCommon *pcommon) {
+ lsoRecord *prec = (lsoRecord *) pcommon;
+ struct outStream *pstream;
+ if (prec->out.type != INST_IO)
+ return S_dev_badOutType;
+ for (pstream = outStreams; pstream->name; ++pstream) {
+ if (strcmp(prec->out.value.instio.string, pstream->name) == 0) {
+ prec->dpvt = pstream;
+ return 0;
+ prec->dpvt = NULL;
+ return -1;
+static long del_lso(dbCommon *pcommon) {
+ return 0;
+static struct dsxt dsxtLsoStdio = {
+ add_lso, del_lso
+static long init_lso(int pass)
+ if (pass == 0) devExtend(&dsxtLsoStdio);
+ return 0;
+static long write_lso(lsoRecord *prec)
+ struct outStream *pstream = (struct outStream *)prec->dpvt;
+ if (pstream)
+ pstream->print("%s\n", prec->val);
+ return 0;
+lsodset devLsoStdio = {
+ 5, NULL, init_lso, NULL, NULL, write_lso
+epicsExportAddress(dset, devLsoStdio);
+/* printf device support */
+static long add_printf(dbCommon *pcommon) {
+ printfRecord *prec = (printfRecord *) pcommon;
+ return 0;
+ return -1;
+static long del_printf(dbCommon *pcommon) {
+ return 0;
+static struct dsxt dsxtPrintfStdio = {
+ add_printf, del_printf
+static long init_printf(int pass)
+ if (pass == 0) devExtend(&dsxtPrintfStdio);
+ return 0;
+static long write_printf(printfRecord *prec)
+ if (pstream)
+ return 0;
+printfdset devPrintfStdio = {
+ 5, NULL, init_printf, NULL, NULL, write_printf
+epicsExportAddress(dset, devPrintfStdio);
+/* stringout device support */
+static long add_stringout(dbCommon *pcommon) {
+ stringoutRecord *prec = (stringoutRecord *) pcommon;
+ return 0;
+ return -1;
+static long del_stringout(dbCommon *pcommon) {
+ return 0;
+static struct dsxt dsxtSoStdio = {
+ add_stringout, del_stringout
+static long init_stringout(int pass)
+ if (pass == 0) devExtend(&dsxtSoStdio);
+ return 0;
+static long write_stringout(stringoutRecord *prec)
+ if (pstream)
+ return 0;
+static struct {
+ dset common;
+ DEVSUPFUN write;
+} devSoStdio = {
+ {5, NULL, init_stringout, NULL, NULL}, write_stringout
+epicsExportAddress(dset, devSoStdio);
=== modified file 'src/std/rec/Makefile'
--- src/std/rec/Makefile 2011-11-14 23:42:50 +0000
+++ src/std/rec/Makefile 2012-12-10 21:21:25 +0000
@@ -11,67 +11,43 @@
SRC_DIRS += $(STDDIR)/rec
-DBDINC += aaiRecord
-DBDINC += aaoRecord
-DBDINC += aiRecord
-DBDINC += aoRecord
-DBDINC += aSubRecord
-DBDINC += biRecord
-DBDINC += boRecord
-DBDINC += calcRecord
-DBDINC += calcoutRecord
-DBDINC += compressRecord
-DBDINC += dfanoutRecord
-DBDINC += eventRecord
-DBDINC += fanoutRecord
-DBDINC += histogramRecord
-DBDINC += longinRecord
-DBDINC += longoutRecord
-DBDINC += mbbiRecord
-DBDINC += mbbiDirectRecord
-DBDINC += mbboRecord
-DBDINC += mbboDirectRecord
-DBDINC += permissiveRecord
-DBDINC += selRecord
-DBDINC += seqRecord
-DBDINC += stateRecord
-DBDINC += stringinRecord
-DBDINC += stringoutRecord
-DBDINC += subRecord
-DBDINC += subArrayRecord
-DBDINC += waveformRecord
+stdRecords += aaiRecord
+stdRecords += aaoRecord
+stdRecords += aiRecord
+stdRecords += aoRecord
+stdRecords += aSubRecord
+stdRecords += biRecord
+stdRecords += boRecord
+stdRecords += calcRecord
+stdRecords += calcoutRecord
+stdRecords += compressRecord
+stdRecords += dfanoutRecord
+stdRecords += eventRecord
+stdRecords += fanoutRecord
+stdRecords += histogramRecord
+stdRecords += longinRecord
+stdRecords += longoutRecord
+stdRecords += lsiRecord
+stdRecords += lsoRecord
+stdRecords += mbbiRecord
+stdRecords += mbbiDirectRecord
+stdRecords += mbboRecord
+stdRecords += mbboDirectRecord
+stdRecords += permissiveRecord
+stdRecords += printfRecord
+stdRecords += selRecord
+stdRecords += seqRecord
+stdRecords += stateRecord
+stdRecords += stringinRecord
+stdRecords += stringoutRecord
+stdRecords += subRecord
+stdRecords += subArrayRecord
+stdRecords += waveformRecord
+DBDINC += $(stdRecords)
DBD += stdRecords.dbd
-stdRecords_DBD = $(patsubst %,%.dbd,$(DBDINC))
+stdRecords_DBD = $(patsubst %,%.dbd,$(stdRecords))
-dbRecStd_SRCS += aaiRecord.c
-dbRecStd_SRCS += aaoRecord.c
-dbRecStd_SRCS += aiRecord.c
-dbRecStd_SRCS += aoRecord.c
-dbRecStd_SRCS += aSubRecord.c
-dbRecStd_SRCS += biRecord.c
-dbRecStd_SRCS += boRecord.c
-dbRecStd_SRCS += calcRecord.c
-dbRecStd_SRCS += calcoutRecord.c
-dbRecStd_SRCS += compressRecord.c
-dbRecStd_SRCS += dfanoutRecord.c
-dbRecStd_SRCS += eventRecord.c
-dbRecStd_SRCS += fanoutRecord.c
-dbRecStd_SRCS += histogramRecord.c
-dbRecStd_SRCS += longinRecord.c
-dbRecStd_SRCS += longoutRecord.c
-dbRecStd_SRCS += mbbiRecord.c
-dbRecStd_SRCS += mbbiDirectRecord.c
-dbRecStd_SRCS += mbboRecord.c
-dbRecStd_SRCS += mbboDirectRecord.c
-dbRecStd_SRCS += permissiveRecord.c
-dbRecStd_SRCS += selRecord.c
-dbRecStd_SRCS += seqRecord.c
-dbRecStd_SRCS += stateRecord.c
-dbRecStd_SRCS += stringinRecord.c
-dbRecStd_SRCS += stringoutRecord.c
-dbRecStd_SRCS += subRecord.c
-dbRecStd_SRCS += subArrayRecord.c
-dbRecStd_SRCS += waveformRecord.c
+dbRecStd_SRCS += $(patsubst %,%.c,$(stdRecords))
=== modified file 'src/std/rec/RULES'
--- src/std/rec/RULES 2011-02-27 00:24:51 +0000
+++ src/std/rec/RULES 2012-12-10 21:21:25 +0000
@@ -9,7 +9,7 @@
# This is a Makefile fragment, see src/std/Makefile.
-$(COMMON_DIR)/stdRecords.dbd:
+$(COMMON_DIR)/stdRecords.dbd: ../rec/Makefile
$(RM) $@
$(PERL) $(TOOLS)/makeIncludeDbd.pl $(stdRecords_DBD) $@
=== added file 'src/std/rec/lsiRecord.c'
--- src/std/rec/lsiRecord.c 1970-01-01 00:00:00 +0000
+++ src/std/rec/lsiRecord.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,284 @@
+/* Long String Input record type */
+ * Date: 2012-11-27
+#include <stddef.h>
+#include <stdio.h>
+#include "dbDefs.h"
+#include "alarm.h"
+#include "cantProceed.h"
+#include "dbEvent.h"
+#include "dbFldTypes.h"
+#include "errMdef.h"
+#include "menuPost.h"
+#include "menuYesNo.h"
+#include "special.h"
+#define GEN_SIZE_OFFSET
+#undef GEN_SIZE_OFFSET
+static void monitor(lsiRecord *);
+static long readValue(lsiRecord *);
+static long init_record(lsiRecord *prec, int pass)
+ lsidset *pdset;
+ if (pass == 0) {
+ size_t sizv = prec->sizv;
+ if (sizv < 16) {
+ sizv = 16; /* Enforce a minimum size for the VAL field */
+ prec->sizv = sizv;
+ prec->val = callocMustSucceed(1, sizv, "lsi::init_record");
+ prec->len = 0;
+ prec->oval = callocMustSucceed(1, sizv, "lsi::init_record");
+ prec->olen = 0;
+ return 0;
+ dbLoadLink(&prec->siml, DBF_USHORT, &prec->simm);
+ pdset = (lsidset *) prec->dset;
+ if (!pdset) {
+ recGblRecordError(S_dev_noDSET, prec, "lsi: init_record");
+ return S_dev_noDSET;
+ /* must have a read_string function */
+ if (pdset->number < 5 || !pdset->read_string) {
+ recGblRecordError(S_dev_missingSup, prec, "lsi: init_record");
+ return S_dev_missingSup;
+ if (pdset->init_record) {
+ long status = pdset->init_record(prec);
+ if (status)
+ return status;
+ if (prec->len) {
+ strcpy(prec->oval, prec->val);
+ prec->olen = prec->len;
+ prec->udf = FALSE;
+ return 0;
+static long process(lsiRecord *prec)
+ int pact = prec->pact;
+ lsidset *pdset = (lsidset *) prec->dset;
+ long status = 0;
+ if (!pdset || !pdset->read_string) {
+ recGblRecordError(S_dev_missingSup, prec, "lsi: read_string");
+ status = readValue(prec); /* read the new value */
+ if (!pact && prec->pact)
+ return 0;
+ recGblGetTimeStamp(prec);
+ monitor(prec);
+ /* Wrap up */
+ recGblFwdLink(prec);
+ prec->pact = FALSE;
+ return status;
+static long cvt_dbaddr(DBADDR *paddr)
+ lsiRecord *prec = (lsiRecord *) paddr->precord;
+ int fieldIndex = dbGetFieldIndex(paddr);
+ if (fieldIndex == lsiRecordVAL) {
+ paddr->pfield = prec->val;
+ paddr->special = SPC_MOD;
+ else if (fieldIndex == lsiRecordOVAL) {
+ paddr->pfield = prec->oval;
+ paddr->special = SPC_NOMOD;
+ else {
+ errlogPrintf("lsiRecord::cvt_dbaddr called for %s.%s\n",
+ prec->name, paddr->pfldDes->name);
+ return -1;
+ paddr->field_type = DBF_STRING;
+ paddr->dbr_field_type = DBF_STRING;
+ paddr->field_size = prec->sizv;
+ return 0;
+static long get_array_info(DBADDR *paddr, long *no_elements, long *offset)
+ *no_elements = prec->len;
+ *no_elements = prec->olen;
+ else
+ return -1;
+ *offset = 0;
+ return 0;
+static long put_array_info(DBADDR *paddr, long nNew)
+ if (nNew == prec->sizv)
+ --nNew; /* truncated string */
+ prec->val[nNew] = 0; /* ensure data is terminated */
+ return 0;
+static long special(DBADDR *paddr, int after)
+ if (!after)
+ return 0;
+ /* We set prec->len here and not in put_array_info()
+ * because that does not get called if the put was
+ * done using a DBR_STRING type.
+ prec->len = strlen(prec->val) + 1;
+ db_post_events(prec, &prec->len, DBE_VALUE | DBE_LOG);
+ return 0;
+static void monitor(lsiRecord *prec)
+ epicsUInt16 events = recGblResetAlarms(prec);
+ if (prec->len != prec->olen ||
+ memcmp(prec->oval, prec->val, prec->len)) {
+ events |= DBE_VALUE | DBE_LOG;
+ memcpy(prec->oval, prec->val, prec->len);
+ if (prec->len != prec->olen) {
+ if (prec->mpst == menuPost_Always)
+ events |= DBE_VALUE;
+ if (prec->apst == menuPost_Always)
+ events |= DBE_LOG;
+ if (events)
+ db_post_events(prec, prec->val, events);
+static long readValue(lsiRecord *prec)
+ long status;
+ if (prec->pact)
+ goto read;
+ status = dbGetLink(&prec->siml, DBR_USHORT, &prec->simm, 0, 0);
+ if (status)
+ return status;
+ switch (prec->simm) {
+ case menuYesNoNO:
+read:
+ status = pdset->read_string(prec);
+ break;
+ case menuYesNoYES:
+ recGblSetSevr(prec, SIMM_ALARM, prec->sims);
+ status = dbGetLinkLS(&prec->siol, prec->val, prec->sizv, &prec->len);
+ break;
+ default:
+ recGblSetSevr(prec, SOFT_ALARM, INVALID_ALARM);
+ status = -1;
+ if (!status)
+ return status;
+/* Create Record Support Entry Table*/
+#define report NULL
+#define initialize NULL
+/* init_record */
+/* process */
+/* special */
+#define get_value NULL
+/* cvt_dbaddr */
+/* get_array_info */
+/* put_array_info */
+#define get_units NULL
+#define get_precision NULL
+#define get_enum_str NULL
+#define get_enum_strs NULL
+#define put_enum_str NULL
+#define get_graphic_double NULL
+#define get_control_double NULL
+#define get_alarm_double NULL
+rset lsiRSET = {
+ RSETNUMBER,
+ report,
+ initialize,
+ init_record,
+ process,
+ special,
+ get_value,
+ cvt_dbaddr,
+ get_array_info,
+ put_array_info,
+ get_units,
+ get_precision,
+ get_enum_str,
+ get_enum_strs,
+ put_enum_str,
+ get_graphic_double,
+ get_control_double,
+ get_alarm_double
+epicsExportAddress(rset, lsiRSET);
=== added file 'src/std/rec/lsiRecord.dbd'
--- src/std/rec/lsiRecord.dbd 1970-01-01 00:00:00 +0000
+++ src/std/rec/lsiRecord.dbd 2012-12-10 21:21:25 +0000
@@ -0,0 +1,88 @@
+recordtype(lsi) {
+ include "dbCommon.dbd"
+ %#include "devSup.h"
+ %/* Declare Device Support Entry Table */
+ %typedef struct lsidset {
+ % long number;
+ % DEVSUPFUN report;
+ % DEVSUPFUN init;
+ % DEVSUPFUN init_record;
+ % DEVSUPFUN get_ioint_info;
+ % DEVSUPFUN read_string;
+ %} lsidset;
+ field(VAL,DBF_NOACCESS) {
+ prompt("Current Value")
+ asl(ASL0)
+ pp(TRUE)
+ special(SPC_DBADDR)
+ extra("char *val")
+ field(OVAL,DBF_NOACCESS) {
+ prompt("Old Value")
+ interest(3)
+ extra("char *oval")
+ field(SIZV,DBF_USHORT) {
+ prompt("Size of buffers")
+ promptgroup(GUI_OUTPUT)
+ special(SPC_NOMOD)
+ interest(1)
+ initial("41")
+ field(LEN,DBF_ULONG) {
+ prompt("Length of VAL")
+ field(OLEN,DBF_ULONG) {
+ prompt("Length of OVAL")
+ field(INP,DBF_INLINK) {
+ prompt("Input Specification")
+ promptgroup(GUI_INPUTS)
+ interest(1)
+ field(MPST,DBF_MENU) {
+ prompt("Post Value Monitors")
+ promptgroup(GUI_DISPLAY)
+ interest(1)
+ menu(menuPost)
+ field(APST,DBF_MENU) {
+ prompt("Post Archive Monitors")
+ interest(1)
+ menu(menuPost)
+ field(SIML,DBF_INLINK) {
+ prompt("Simulation Mode Link")
+ interest(2)
+ field(SIMM,DBF_MENU) {
+ prompt("Simulation Mode")
+ interest(2)
+ menu(menuYesNo)
+ field(SIMS,DBF_MENU) {
+ prompt("Simulation Mode Severity")
+ interest(2)
+ menu(menuAlarmSevr)
+ field(SIOL,DBF_INLINK) {
+ prompt("Sim Input Specifctn")
+ interest(2)
=== added file 'src/std/rec/lsoRecord.c'
--- src/std/rec/lsoRecord.c 1970-01-01 00:00:00 +0000
+++ src/std/rec/lsoRecord.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,322 @@
+/* Long String Output record type */
+#include <stdio.h>
+#include "alarm.h"
+#include "menuIvoa.h"
+#include "menuOmsl.h"
+static void monitor(lsoRecord *);
+static long writeValue(lsoRecord *);
+static long init_record(lsoRecord *prec, int pass)
+ lsodset *pdset;
+ if (pass == 0) {
+ if (sizv < 16) {
+ prec->val = callocMustSucceed(1, sizv, "lso::init_record");
+ prec->len = 0;
+ prec->oval = callocMustSucceed(1, sizv, "lso::init_record");
+ prec->olen = 0;
+ return 0;
+ pdset = (lsodset *) prec->dset;
+ if (!pdset) {
+ recGblRecordError(S_dev_noDSET, prec, "lso: init_record");
+ /* must have a write_string function defined */
+ if (pdset->number < 5 || !pdset->write_string) {
+ recGblRecordError(S_dev_missingSup, prec, "lso: init_record");
+ dbLoadLinkLS(&prec->dol, prec->val, prec->sizv, &prec->len);
+ if (status)
+ return status;
+ if (prec->len) {
+ return 0;
+static long process(lsoRecord *prec)
+ lsodset *pdset = (lsodset *) prec->dset;
+ long status = 0;
+ if (!pdset || !pdset->write_string) {
+ recGblRecordError(S_dev_missingSup, prec, "lso: write_string");
+ if (!pact && prec->omsl == menuOmslclosed_loop)
+ if (!dbGetLinkLS(&prec->dol, prec->val, prec->sizv, &prec->len))
+ if (prec->udf)
+ recGblSetSevr(prec, UDF_ALARM, INVALID_ALARM);
+ if (prec->nsev < INVALID_ALARM )
+ status = writeValue(prec); /* write the new value */
+ else {
+ switch (prec->ivoa) {
+ case menuIvoaContinue_normally:
+ break;
+ case menuIvoaDon_t_drive_outputs:
+ break;
+ case menuIvoaSet_output_to_IVOV:
+ if (!prec->pact) {
+ size_t size = prec->sizv - 1;
+ strncpy(prec->val, prec->ivov, size);
+ prec->val[size] = 0;
+ break;
+ default:
+ status = -1;
+ recGblRecordError(S_db_badField, prec,
+ "lso:process Bad IVOA choice");
+ /* Asynchronous if device support set pact */
+ return status;
+ monitor(prec);
+ /* Wrap up */
+ return status;
+ lsoRecord *prec = (lsoRecord *) paddr->precord;
+ if (fieldIndex == lsoRecordVAL) {
+ else if (fieldIndex == lsoRecordOVAL) {
+ else {
+ errlogPrintf("lsoRecord::cvt_dbaddr called for %s.%s\n",
+ return -1;
+ return 0;
+ else
+ return -1;
+ *offset = 0;
+ return 0;
+ return 0;
+ if (!after)
+ return 0;
+ return 0;
+static void monitor(lsoRecord *prec)
+ if (events)
+static long writeValue(lsoRecord *prec)
+ long status;
+ if (prec->pact)
+ goto write;
+ if (status)
+ return(status);
+ case menuYesNoNO:
+write:
+ status = pdset->write_string(prec);
+ break;
+ status = dbPutLink(&prec->siol,DBR_STRING, prec->val,1);
+ break;
+ default:
+ status = -1;
+ return status;
+/* init_record */
+/* process */
+/* special */
+/* cvt_dbaddr */
+rset lsoRSET = {
+ RSETNUMBER,
+ report,
+ initialize,
+ init_record,
+ process,
+ special,
+ get_value,
+ cvt_dbaddr,
+ get_array_info,
+ put_array_info,
+ get_units,
+ get_precision,
+ get_enum_str,
+ get_enum_strs,
+ put_enum_str,
+ get_alarm_double
+epicsExportAddress(rset, lsoRSET);
=== added file 'src/std/rec/lsoRecord.dbd'
--- src/std/rec/lsoRecord.dbd 1970-01-01 00:00:00 +0000
+++ src/std/rec/lsoRecord.dbd 2012-12-10 21:21:25 +0000
@@ -0,0 +1,112 @@
+recordtype(lso) {
+ %typedef struct lsodset {
+ % long number;
+ % DEVSUPFUN init;
+ % DEVSUPFUN write_string;
+ %} lsodset;
+ asl(ASL0)
+ pp(TRUE)
+ prompt("Previous Value")
+ interest(3)
+ interest(1)
+ initial("41")
+ interest(3)
+ field(DOL,DBF_INLINK) {
+ prompt("Desired Output Link")
+ interest(1)
+ field(IVOA,DBF_MENU) {
+ prompt("INVALID Output Action")
+ interest(2)
+ menu(menuIvoa)
+ field(IVOV,DBF_STRING) {
+ prompt("INVALID Output Value")
+ interest(2)
+ size(40)
+ field(OMSL,DBF_MENU) {
+ prompt("Output Mode Select")
+ interest(1)
+ menu(menuOmsl)
+ field(OUT,DBF_OUTLINK) {
+ prompt("Output Specification")
+ interest(1)
+ interest(1)
+ menu(menuPost)
+ interest(1)
+ menu(menuPost)
+ prompt("Sim Mode link")
+ interest(1)
+ interest(1)
+ menu(menuYesNo)
+ prompt("Sim mode Alarm Svrty")
+ interest(2)
+ field(SIOL,DBF_OUTLINK) {
+ prompt("Sim Output Specifctn")
+ interest(1)
=== added file 'src/std/rec/printfRecord.c'
--- src/std/rec/printfRecord.c 1970-01-01 00:00:00 +0000
+++ src/std/rec/printfRecord.c 2012-12-10 21:21:25 +0000
@@ -0,0 +1,438 @@
+/* Printf record type */
+ * Date: 2012-09-18
+#include "alarm.h"
+#include "epicsMath.h"
+#include "epicsStdio.h"
+/* Flag bits */
+#define F_CHAR 1
+#define F_SHORT 2
+#define F_LONG 4
+#define F_LEFT 8
+#define F_BADFMT 0x10
+#define F_BADLNK 0x20
+#define F_BAD (F_BADFMT | F_BADLNK)
+#define GET_PRINT(VALTYPE, DBRTYPE) \
+ VALTYPE val; \
+ int ok; \
+ if (plink->type == CONSTANT) \
+ ok = recGblInitConstantLink(plink++, DBRTYPE, &val); \
+ else \
+ ok = ! dbGetLink(plink++, DBRTYPE, &val, 0, 0); \
+ if (ok) \
+ added = epicsSnprintf(pval, vspace + 1, format, val); \
+ else \
+ flags |= F_BADLNK
+static void doPrintf(printfRecord *prec)
+ const char *pfmt = prec->fmt;
+ DBLINK *plink = &prec->inp0;
+ int linkn = 0;
+ char *pval = prec->val;
+ int vspace = prec->sizv - 1;
+ int ch;
+ while (vspace > 0 && (ch = *pfmt++)) {
+ if (ch != '%') {
+ /* Copy literal strings directly into prec->val */
+ *pval++ = ch;
+ --vspace;
+ else {
+ char format[20];
+ char *pformat = format;
+ int width = 0;
+ int precision = 0;
+ int *pnum = &width;
+ int flags = 0;
+ int added = 0;
+ int cont = 1;
+ /* The format directive parsing here is not comprehensive,
+ * in most cases we just copy each directive into format[]
+ * and get epicsSnprintf() do all the work. We do replace
+ * all variable-length field width or precision '*' chars
+ * with an integer read from the next input link, and we
+ * also convert %ls (long string) directives ourself, so
+ * we need to know the width, precision and justification.
+ *pformat++ = ch; /* '%' */
+ while (cont && (ch = *pfmt++)) {
+ *pformat++ = ch;
+ switch (ch) {
+ case '+': case ' ': case '#':
+ break;
+ case '-':
+ flags |= F_LEFT;
+ break;
+ case '.':
+ pnum = &precision;
+ break;
+ case '0': case '1': case '2': case '3': case '4':
+ case '5': case '6': case '7': case '8': case '9':
+ *pnum = *pnum * 10 + ch - '0';
+ break;
+ case '*':
+ if (*pnum) {
+ flags |= F_BADFMT;
+ else if (linkn++ < PRINTF_NLINKS) {
+ epicsInt16 i;
+ int ok;
+ ok = recGblInitConstantLink(plink++, DBR_SHORT, &i);
+ else
+ ok = ! dbGetLink(plink++, DBR_SHORT, &i, 0, 0);
+ if (ok) {
+ *pnum = i;
+ added = epicsSnprintf(--pformat, 6, "%d", i);
+ pformat += added;
+ else /* No more LNKn fields */
+ flags |= F_BADLNK;
+ else
+ break;
+ case 'h':
+ if (flags & F_SHORT)
+ flags = (flags & ~F_SHORT) | F_CHAR;
+ else
+ flags |= F_SHORT;
+ break;
+ case 'l':
+ flags |= F_LONG;
+ break;
+ default:
+ if (strchr("diouxXeEfFgGcs%", ch) == NULL)
+ cont = 0;
+ break;
+ if (!ch) /* End of format string */
+ break;
+ if (flags & F_BAD)
+ goto bad_format;
+ *pformat = 0; /* Terminate our format string */
+ if (width < 0) {
+ width = -width;
+ flags |= F_LEFT;
+ if (precision < 0)
+ precision = 0;
+ if (ch == '%') {
+ added = epicsSnprintf(pval, vspace + 1, format);
+ else if (linkn++ >= PRINTF_NLINKS) {
+ /* No more LNKn fields */
+ else
+ switch (ch) { /* Conversion character */
+ case 'c': case 'd': case 'i':
+ if (ch == 'c' || flags & F_CHAR) {
+ GET_PRINT(epicsInt8, DBR_CHAR);
+ else if (flags & F_SHORT) {
+ GET_PRINT(epicsInt16, DBR_SHORT);
+ else { /* F_LONG has no real effect */
+ GET_PRINT(epicsInt32, DBR_LONG);
+ break;
+ case 'o': case 'x': case 'X': case 'u':
+ if (flags & F_CHAR) {
+ GET_PRINT(epicsUInt8, DBR_UCHAR);
+ GET_PRINT(epicsUInt16, DBR_USHORT);
+ GET_PRINT(epicsUInt32, DBR_ULONG);
+ break;
+ case 'e': case 'E':
+ case 'f': case 'F':
+ case 'g': case 'G':
+ if (flags & F_SHORT) {
+ GET_PRINT(epicsFloat32, DBR_FLOAT);
+ else {
+ GET_PRINT(epicsFloat64, DBR_DOUBLE);
+ break;
+ case 's':
+ if (flags & F_LONG && plink->type != CONSTANT) {
+ long n = vspace + 1;
+ if (precision && n > precision)
+ n = precision + 1;
+ /* If set, precision is the maximum number of
+ * characters to be printed from the string.
+ * It does not limit the field width however.
+ if (dbGetLink(plink++, DBR_CHAR, pval, 0, &n))
+ else {
+ int padding;
+ /* Terminate string and measure its length */
+ pval[n] = 0;
+ added = strlen(pval);
+ padding = width - added;
+ if (padding > 0) {
+ if (flags & F_LEFT) {
+ /* add spaces on RHS */
+ if (width > vspace)
+ padding = vspace - added;
+ memset(pval + added, ' ', padding);
+ else {
+ /* insert spaces on LHS */
+ int trunc = width - vspace;
+ if (trunc < added) {
+ added -= trunc;
+ memmove(pval + padding, pval, added);
+ else {
+ padding = vspace;
+ added = 0;
+ memset(pval, ' ', padding);
+ added += padding;
+ else {
+ char val[MAX_STRING_SIZE];
+ int ok;
+ ok = recGblInitConstantLink(plink++, DBR_STRING, val);
+ else
+ ok = ! dbGetLink(plink++, DBR_STRING, val, 0, 0);
+ if (ok)
+ else
+ break;
+ default:
+ errlogPrintf("printfRecord: Unexpected conversion '%s'\n",
+ format);
+ break;
+ if (flags & F_BAD) {
+ bad_format:
+ added = epicsSnprintf(pval, vspace + 1, "%s",
+ flags & F_BADLNK ? prec->ivls : format);
+ if (added <= vspace) {
+ pval += added;
+ vspace -= added;
+ else {
+ /* Output was truncated */
+ pval += vspace;
+ vspace = 0;
+ *pval++ = 0; /* Terminate the VAL string */
+ prec->len = pval - prec->val;
+static long init_record(printfRecord *prec, int pass)
+ printfdset *pdset;
+ if (pass == 0) {
+ if (sizv < 16) {
+ prec->val = callocMustSucceed(1, sizv, "printf::init_record");
+ prec->len = 0;
+ return 0;
+ pdset = (printfdset *) prec->dset;
+ if (!pdset)
+ return 0; /* Device support is optional */
+ if (pdset->number < 5) {
+ recGblRecordError(S_dev_missingSup, prec, "printf::init_record");
+ if (status)
+ return status;
+ return 0;
+static long process(printfRecord *prec)
+ long status = 0;
+ epicsUInt16 events;
+ if (!pact) {
+ doPrintf(prec);
+ /* Call device support */
+ if (pdset &&
+ pdset->number >= 5 &&
+ pdset->write_string) {
+ return status;
+ /* Post monitor */
+ events = recGblResetAlarms(prec);
+ db_post_events(prec, prec->val, events | DBE_VALUE | DBE_LOG);
+ db_post_events(prec, &prec->len, events | DBE_VALUE | DBE_LOG);
+ /* Wrap up */
+ return status;
+ printfRecord *prec = (printfRecord *)paddr->precord;
+ if (fieldIndex == printfRecordVAL) {
+ else
+ errlogPrintf("printfRecord::cvt_dbaddr called for %s.%s\n",
+ return 0;
+ printfRecord *prec = (printfRecord *) paddr->precord;
+ *offset = 0;
+ return 0;
+/* Create Record Support Entry Table */
+/* init_record */
+/* process */
+#define special NULL
+/* cvt_dbaddr */
+#define put_array_info NULL
+rset printfRSET = {
+ RSETNUMBER,
+ report,
+ initialize,
+ init_record,
+ process,
+ special,
+ get_value,
+ cvt_dbaddr,
+ get_array_info,
+ put_array_info,
+ get_units,
+ get_precision,
+ get_enum_str,
+ get_enum_strs,
+ put_enum_str,
+ get_alarm_double
+epicsExportAddress(rset, printfRSET);
=== added file 'src/std/rec/printfRecord.dbd'
--- src/std/rec/printfRecord.dbd 1970-01-01 00:00:00 +0000
+++ src/std/rec/printfRecord.dbd 2012-12-10 21:21:25 +0000
@@ -0,0 +1,109 @@
+recordtype(printf) {
+ %typedef struct printfdset {
+ % long number;
+ % DEVSUPFUN init;
+ %} printfdset;
+ prompt("Result")
+ asl(ASL0)
+ pp(TRUE)
+ prompt("Size of VAL buffer")
+ interest(1)
+ initial("41")
+ interest(1)
+ field(FMT,DBF_STRING) {
+ prompt("Format String")
+ promptgroup(GUI_CALC)
+ pp(TRUE)
+ size(81)
+ field(IVLS,DBF_STRING) {
+ prompt("Invalid Link String")
+ size(16)
+ initial("LNK")
+ field(INP0,DBF_INLINK) {
+ prompt("Input 0")
+ interest(1)
+ field(INP1,DBF_INLINK) {
+ prompt("Input 1")
+ interest(1)
+ field(INP2,DBF_INLINK) {
+ prompt("Input 2")
+ interest(1)
+ field(INP3,DBF_INLINK) {
+ prompt("Input 3")
+ interest(1)
+ field(INP4,DBF_INLINK) {
+ prompt("Input 4")
+ interest(1)
+ field(INP5,DBF_INLINK) {
+ prompt("Input 5")
+ interest(1)
+ field(INP6,DBF_INLINK) {
+ prompt("Input 6")
+ interest(1)
+ field(INP7,DBF_INLINK) {
+ prompt("Input 7")
+ interest(1)
+ field(INP8,DBF_INLINK) {
+ prompt("Input 8")
+ interest(1)
+ field(INP9,DBF_INLINK) {
+ prompt("Input 9")
+ interest(1)
+ %/* Number of INPx fields defined */
+ %#define PRINTF_NLINKS 10
Re: [Merge] lp:~anj/epics-base/udf-severity into lp:epics-base Ben Franksen
<2012>
<2012>
