g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: [Merge] lp:~anj/epics-base/udf-severity into lp:epics-base
From: Ben Franksen <benjamin.franksen@helmholtz-berlin.de>
To: Andrew Johnson <anj@aps.anl.gov>
Date: Mon, 10 Dec 2012 19:34:19 -0000
Am Montag, 10. Dezember 2012, 17:28:16 schrieb Andrew Johnson:
> Andrew Johnson has proposed merging lp:~anj/epics-base/udf-severity into
> lp:epics-base.
> Requested reviews:
>   EPICS Core Developers (epics-core)
> For more details, see:
> https://code.launchpad.net/~anj/epics-base/udf-severity/+merge/139024
> This branch adds a new alarm severity field UDFS to dbCommon, which is used
> as the alarm severity whenever a record is put in an undefined state
> (UDF=TRUE).  It defaults to INVALID, so there should be no change to the
> default behavior of existing databases.  Out-of-tree record types will
> need upgrading to implement this properly, usually in the checkAlarms()
> routine; the base record types that check UDF have been modified in this
> branch.
I appreciate that you communicate this change before merging, even though I am
clearly in favour.
> I'm not sure whether doing this is a good idea or not; I suspect it would
> be very useful in some cases,
Indeed.
> but there could be bad effects on databases
> that have been designed to use IVOA and someone who doesn't understand the
> design changes UDFS on some critical record(s).  Discussion encouraged.
Make the change clear and prominent in the release notes. Users who upgrade
their base should have at least one person on site who knows something about
EPICS base and what this change might impact.
Cheers
Ben Franksen
()  ascii ribbon campaign - against html e-mail
/\  www.asciiribbon.org   - against proprietary attachments
Aufsichtsrat: Vorsitzender Prof. Dr. Dr. h.c. mult. Joachim Treusch, stv. Vorsitzende Dr. Beatrix Vierkorn-Rudolph
Geschäftsführung: Prof. Dr. Anke Rita Kaysser-Pyzalla, Thomas Frederking
Postadresse:
Hahn-Meitner-Platz 1
D-14109 Berlin
Your team EPICS Core Developers is requested to review the proposed merge of lp:~anj/epics-base/udf-severity into lp:epics-base.
[Merge] lp:~anj/epics-base/udf-severity into lp:epics-base Andrew Johnson
Prev: [Merge] lp:~anj/epics-base/udf-severity into lp:epics-base Andrew Johnson
Next: [Merge] lp:~epics-core/epics-base/printf-record into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 10 Dec 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
