g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: Base R3.14.12.3-pre1 available
To: <anj@aps.anl.gov>
Cc: core-talk@aps.anl.gov, Franck.DiMaio@iter.org
Date: Fri, 30 Nov 2012 20:55:07 +0000
Hi Andrew,
Thanks. Regarding the working TCP stack on Windows the answer is  (I think) yes - it is our Windows terminal server machine and I was logged in using remote desktop at the time. However that doesn't rule out other problems. The compiler and c support libraries are also fairly recent. Any diagnostic suggestions would be welcome. I will also run the R3.14.12.1 tests to see if the result is the same.
Cheers,
Nick Rees
Principal Software Engineer           Phone: +44 (0)1235-778430
Diamond Light Source                  Fax:   +44 (0)1235-446713
Andrew Johnson <anj@aps.anl.gov> wrote:
Hi Nick,
On 2012-11-30 nick.rees@diamond.ac.uk wrote:
> I have just tried building R3.14.12.3-pre1 on Windows server 2008R2 and get
>  the following error - and I am not enough of a C++ expert to unwind what
>  is needed:
Thanks for that report, Janet confirmed it so I just reverted the commit that
modified epicsSingleton.h a couple of weeks ago.
> I also tried building on RHEL6, linux-x86_64. This worked.
[I usually use 'make -s runtests' to silence the output from GNUmake and just
display the test results BTW.]
> The test output
> is:
> [npr78@pc0018 test]$ make runtests
> All tests successful.
> Files=25, Tests=2006, 396 wallclock secs ( 0.48 usr  0.08 sys +  1.01 cusr
>  0.58 csys =  2.15 CPU) Result: PASS
> Is this what is expected? How many tests are meant to pass?
Those numbers are right for src/libCom/test; if you do the 'make runtests'
from the top level directory it also runs a second set of tests in src/db/test
but they're not likely to fail.
> Finally, because I couldn't test R3.14.12.3, I tried to run make runtests
>  on a fully patched version of R3.14.12.2 on Windows Server 2008R2 64 bit
>  and got:
> epicsCalcTest.t ............ Failed 2/566 subtests
> epicsMathTest.t ............ Failed 6/35 subtests
Those failures are known bugs in some versions of Microsoft's optimizer, which
assumes for example that the expression X-X will always give 0 (not true when
X is NaN).
> blockingSockTest.t .........
> A call to 'assert(this->sock != INVALID_SOCKET)'
>     by thread 'win2a8' failed in ..\blockingSockTest.cpp line 172.
> EPICS Release EPICS R3.14.12.2 $Date: Mon 2011-12-12 14:09:32 -0600$.
> Local time is 2012-11-30 18:30:58.382980961 GMT Standard Time
> Please E-mail this message to the author or to tech-talk@aps.anl.gov
> Calling epicsThreadSuspendSelf()
Interesting, we don't get that here; that's one of Jeff's tests, and it
implies that socket() returned an invalid socket.  Did you have a working
TCP/IP network connected to the machine at the time?
- Andrew
Computer science is as much about computers as astronomy is about
telescopes. -- Edsger Dijkstra
Prev: Re: Base R3.14.12.3-pre1 available Andrew Johnson
Next: RE: Base R3.14.12.3-pre1 available nick.rees
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Next: [Bug 1083193] Re: Lifetime of CALLBACK undocumented Ralph Lange
ANJ, 03 Dec 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
