g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: [Bug 1083193] Re: Lifetime of CALLBACK undocumented
To: core-talk@aps.anl.gov
Date: Tue, 27 Nov 2012 13:44:44 -0000
** Also affects: epics-appdev
   Importance: Undecided
       Status: New
** No longer affects: epics-base
You received this bug notification because you are a member of EPICS
Core Developers, which is subscribed to EPICS Application Developers'
Guide.
https://bugs.launchpad.net/bugs/1083193
Title:
Status in EPICS Application Developers' Guide:
  New
Bug description:
  From looking at the (3.14.12) code it is apparent that the CALLBACK
  argument to 'callbackRequest(CALLBACK *pcbck)' is passed by reference.
  However, it is undocumented for how long the CALLBACK object is in
  'possession' of the callback facility, i.e., when it is safe to re-use
  a static CALLBACK object or to free a dynamically created one. In
  particular, it should IMO be documented/defined if it is safe to reuse
  or free a CALLBACK from the callback function itself. It does seem so
  under the current (3.14.12) code which does not access CALLBACK after
  executing the associated function but it would IMO be nice to document
  the exact semantics.
To manage notifications about this bug go to:
https://bugs.launchpad.net/epics-appdev/+bug/1083193/+subscriptions
Prev: Re: RFC: libCom/osi - new spinlock API Andrew Johnson
Next: RE: Base R3.14.12.3-pre1 available nick.rees
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: Base R3.14.12.3-pre1 available nick.rees
Next: mbboDirect changes Andrew Johnson
ANJ, 06 Dec 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
