On Wed Oct 17 2012 18:53:56 GMT-0400 (EDT), Andrew Johnson
<anj@aps.anl.gov> wrote:
> Hi Ralph,
> On 2012-10-17 Ralph Lange wrote:
>> epicsShareFunc void epicsSpinLock(epicsSpinId, epicsSpinKey*);
>> epicsShareFunc int epicsSpinTryLock(epicsSpinId, epicsSpinKey*);
>> epicsShareFunc void epicsSpinUnlock(epicsSpinId, epicsSpinKey*);
>> The epicsSpinKey is used for implementations that need to persist a
>> piece of status data between lock and unlock calls, e.g. intLock().
> Wouldn't it be possible to store that state as a field in the epicsSpin
> structure itself, protected by the spin-lock? The Lock() and TryLock()
> functions would set the field only if/after they succeed, and the value would
> be read by the Unlock() function which can only be called by the lock's
> current owner anyway. Spin-locks cannot be taken recursively, so I think this
> should be safe and it would save having a separate variable in the calling
> code.
I agree and will change it that way.
>> At the same time the existing epicsInterruptLock() API would be deprecated.
> Maybe it could be reimplemented using an epicsSpinLock on some architectures,
> but I think it's pretty heavily used by upgraded vxWorks drivers here so I'd
> want quite a long deprecation cycle before removing it.
Sure, an eternal deprecation cycle would be fine with me...
Reimplementing epicsInterruptLock() as an epicsSpinLock is a good idea
for vxWorks, where the current implementation would break on SMP
architectures.
> BTW, if pthread_spin_lock() is not implemented, using a native pthread_mutex_t
> might be lighter weight than an epicsMutex object.
On Posix, yes. (Only slightly though, as the Posix implementation of
epicsMutex uses pthread_mutex_t.)
The Default should be epicsMutex, to make things work on Windows etc.
until specific implementations are in place.
Thanks for your comments!
~Ralph
- Re: RFC: libCom/osi - new spinlock API Andrew Johnson
- RFC: libCom/osi - new spinlock API Ralph Lange
<2012>
<2012>
