2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: RFC: libCom/osi - new spinlock API
To: [email protected]
Date: Wed, 17 Oct 2012 17:53:56 -0500
Hi Ralph,
On 2012-10-17 Ralph Lange wrote:
> epicsShareFunc void epicsSpinLock(epicsSpinId, epicsSpinKey*);
> epicsShareFunc int epicsSpinTryLock(epicsSpinId, epicsSpinKey*);
> epicsShareFunc void epicsSpinUnlock(epicsSpinId, epicsSpinKey*);
> The epicsSpinKey is used for implementations that need to persist a
> piece of status data between lock and unlock calls, e.g. intLock().
Wouldn't it be possible to store that state as a field in the epicsSpin
structure itself, protected by the spin-lock?  The Lock() and TryLock()
functions would set the field only if/after they succeed, and the value would
be read by the Unlock() function which can only be called by the lock's
current owner anyway.  Spin-locks cannot be taken recursively, so I think this
should be safe and it would save having a separate variable in the calling
code.
> At the same time the existing epicsInterruptLock() API would be deprecated.
Maybe it could be reimplemented using an epicsSpinLock on some architectures,
but I think it's pretty heavily used by upgraded vxWorks drivers here so I'd
want quite a long deprecation cycle before removing it.
BTW, if pthread_spin_lock() is not implemented, using a native pthread_mutex_t
might be lighter weight than an epicsMutex object.
<tangent>
Why does each posix epicsMutex object have its own pthread_mutexattr_t object,
rather than sharing one for all epicsMutex objects we create?  The mutexAttr
member is only referenced in the Create() and Destroy() functions, and the
Linux manpage says that it's only used to initialize the mutex anyway so these
copies are all unnecessary and are bloating the struct epicsMutexOSD.
I guess the question is how to create a shared pthread_mutexattr_t object in a
thread-safe manner; that could be delegated to the posix/osdThread.c::once()
function, but epicsMutexOsdCreate should check to make sure it exists and if
not create, use and then destroy a private copy instead (without trying to
initialize the shared one, so this doesn't become the double-checked locking
pattern).  We can't use an atomic variable because on some architectures that
might need to use an epicsMutex for synchronization...
The same is true of the pthread_condattr_t object in the second implementation
in the posix/osdMutex.c file BTW.
</tangent>
- Andrew
Never interrupt your enemy when he is making a mistake.
-- Napoleon Bonaparte
Re: RFC: libCom/osi - new spinlock API Ralph Lange
Prev: RFC: libCom/osi - new spinlock API Ralph Lange
Next: Re: RFC: libCom/osi - new spinlock API Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
