All,
based on a recent thread on core-talk [1], the current proposal for
a spinlock API to be put into libCom/osi looks like this:
typedef struct epicsSpin *epicsSpinId;
typedef unsigned long epicsSpinKey;
epicsShareFunc epicsSpinId epicsSpinCreate();
epicsShareFunc void epicsSpinDestroy(epicsSpinId);
epicsShareFunc void epicsSpinLock(epicsSpinId,
epicsSpinKey*);
epicsShareFunc int epicsSpinTryLock(epicsSpinId,
epicsSpinKey*);
epicsShareFunc void epicsSpinUnlock(epicsSpinId,
epicsSpinKey*);
These are intended to allow for granular locking, and to be safe to
use from an ISR (when applicable).
The implementation would be based on:
vxWorks - single core: intLock()
vxWorks - multi core: ISR-callable spinlocks
RTEMS: pthread_spin_lock() (or SuperCore spinlocks?)
Posix: pthread_spin_lock() (if implemented, else epicsMutex)
Default: epicsMutex
The epicsSpinKey is used for implementations that need to persist a
piece of status data between lock and unlock calls, e.g. intLock().
At the same time the existing epicsInterruptLock() API would be
deprecated.
Comments are very welcome.
~Ralph
[1]
http://www.aps.anl.gov/epics/core-talk/2012/msg00035.php
- Re: RFC: libCom/osi - new spinlock API Andrew Johnson
[Merge] lp:~jlmuir/epics-base/caput-help-F-opt-3.15 into lp:epics-base noreply
<2012>
<2012>
ANJ, 26 Nov 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
