g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: [Merge] lp:~jlmuir/epics-base/caput-help-F-opt-3.15 into lp:epics-base
To: mp+126484@code.launchpad.net
Date: Wed, 26 Sep 2012 15:48:38 -0000
J. Lewis Muir has proposed merging lp:~jlmuir/epics-base/caput-help-F-opt-3.15 into lp:epics-base.
Requested reviews:
  EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~jlmuir/epics-base/caput-help-F-opt-3.15/+merge/126484
Add the '-F' option to the caput program usage message.  The caput program accepts the '-F' option, but the usage message does not tell about it.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~jlmuir/epics-base/caput-help-F-opt-3.15 into lp:epics-base.
=== modified file 'src/ca/client/tools/caput.c'
--- src/ca/client/tools/caput.c	2011-11-07 17:58:09 +0000
+++ src/ca/client/tools/caput.c	2012-09-26 15:47:29 +0000
@@ -74,6 +74,8 @@
     "  -a: Put array\n"
     "      Value format: number of requested values, then list of values\n"
     "  -S: Put string as an array of char (long string)\n"
+    "Alternate output field separator:\n"
+    "  -F <ofs>: Use <ofs> as an alternate output field separator\n"
     "\nExample: caput my_channel 1.2\n"
     "  (puts 1.2 to my_channel)\n\n"
              , DEFAULT_TIMEOUT, CA_PRIORITY_MAX);
Re: [Merge] lp:~jlmuir/epics-base/caput-help-F-opt-3.15 into lp:epics-base Andrew Johnson
[Merge] lp:~jlmuir/epics-base/caput-help-F-opt-3.15 into lp:epics-base noreply
Prev: Re: Building gdd on windows-x64 targets Andrew Johnson
Next: Re: [Merge] lp:~jlmuir/epics-base/caput-help-F-opt-3.15 into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
