g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base
To: mdavidsaver <mdavidsaver@bnl.gov>
Date: Mon, 02 Jul 2012 08:44:17 -0000
> > /* As we're only ever inserting hooks at the head of the list, forward
> traversing is safe */
> > pHook = (epicsThreadHook *) ellFirst(list);
> It can be unlocked to traverse, but the mutex should be locked when fetching
> the head pointer.
That's because the pointer modifying operations (in elllib.c) are not atomic?
Other than that, I would assume the map function could either get or miss the element currently being inserted or added, and both would be ok.
https://code.launchpad.net/~ralph-lange/epics-base/thread-hooks/+merge/112806
Your team EPICS Core Developers is requested to review the proposed merge of lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base.
Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~ralph-lange/epics-base/thread-hooks into lp:epics-base Andrew Johnson
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
