I have a problem running a trivial (too trivial it seems) ca client
program.
I fact I just generated the ca example using makeBaseApp.
I changed caget to caput :)
The value was not written to my ioc
I am running 3.14.12.2, on linux_x86_64 but the behavior seems the same
in older versions (at least 3.14.9(
I am sending this to core-talk rather than tech-talk as this seems to be
a real ca problem
#################################################################################3
#include <stddef.h>
#include <stdlib.h>
#include <stdio.h>
#include <string.h>
#include <cadef.h>
int main (int argc, char *argv[])
double data=86;
chid mychid;
SEVCHK(ca_create_channel(argv[1], NULL, NULL, 10,
&mychid),"failure");
SEVCHK(ca_pend_io(10.0),"failure");
SEVCHK(ca_array_put(DBR_DOUBLE, 1, mychid, &data),"failure");
// SEVCHK(ca_array_get(DBR_DOUBLE, 1, mychid, &data),"failure");
// SEVCHK(ca_pend_io(10.0),"failure");
// SEVCHK(ca_flush_io(),"failure");
// SEVCHK(ca_poll(),"failure");
// sleep(10);
// ca_context_destroy();
// return result;
When I un-comment ca_poll, ca_context_destroy, ca_get (plus its
pend_io), or sleep!!! it works!!!
so a ca_poll, a ca_context_destroy, or a ca_pend_io AFTER a ca_get,
seems to flush the send buffer - but just ca_pend_io, nor ca_flush_io
seem not to do so.
At least the client example generated from makebaseApp should have a
ca_put added, and made to work without the ca_get, but perhaps this
could be considered a bug.
- RE: pend_io Hill, Jeff
Re: [Merge] lp:~epics-core/epics-base/thread-pool into lp:epics-base mdavidsaver
<2012>
[Merge] lp:~dirk.zimoch/epics-base/non-val-attributes into lp:epics-base/3.14 Andrew Johnson
<2012>
