2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: timer delay compensation
Date: Fri, 15 Jun 2012 22:23:51 +0000
Hi Andrew,
No issues that I can see in your new windows version, which I have
maintained in the past, after a quick review.
Jeff
> -----Original Message-----
> From: [email protected] [mailto:[email protected]]
> On Behalf Of Andrew Johnson
> Sent: Friday, June 15, 2012 3:03 PM
> To: [email protected]
> Subject: Re: timer delay compensation
> Hi,
> I will not be working on the documentation change which was Ralph's first
> issue, although if someone else writes the words I don't mind doing the
> necessary edit and commit.
> After spending longer than I should have on the second issue, I propose to
> commit the following changes to the 3.14 branch, which I believe fixes all
> reported issues with the epicsThreadSleep() implementations and makes them
> robust against overflows and negative or NAN arguments.
> === modified file 'src/libCom/osi/os/RTEMS/osdThread.c'
> --- src/libCom/osi/os/RTEMS/osdThread.c 2010-10-05 19:27:37 +0000
> +++ src/libCom/osi/os/RTEMS/osdThread.c 2012-06-15 18:38:51 +0000
> @@ -25,6 +25,7 @@
>  #include <stdio.h>
>  #include <assert.h>
>  #include <syslog.h>
> +#include <limits.h>
>  #include <rtems.h>
>  #include <rtems/error.h>
> @@ -364,17 +365,16 @@
>      rtems_status_code sc;
>      rtems_interval delay;
> -    extern double rtemsTicksPerTwoSeconds_double;
> -    if (seconds <= 0.0) {
> +    extern double rtemsTicksPerSecond_double;
> +    if (seconds > 0.0) {
> +        seconds *= rtemsTicksPerSecond_double;
> +        seconds += 0.99999999;  /* 8 9s here is optimal */
> +        delay = (seconds >= INT_MAX) ? INT_MAX : (int) seconds;
> +    else {  /* seconds <= 0 or NAN */
>          delay = 0;
> -    else {
> -        delay = seconds * rtemsTicksPerTwoSeconds_double;
> -        delay = (delay + 1) / 2;
> -        if (delay == 0)
> -            delay++;
>      sc = rtems_task_wake_after (delay);
>      if(sc != RTEMS_SUCCESSFUL)
>          errlogPrintf("epicsThreadSleep: %s\n", rtems_status_text (sc));
> === modified file 'src/libCom/osi/os/WIN32/osdThread.c'
> --- src/libCom/osi/os/WIN32/osdThread.c 2012-02-03 00:14:01 +0000
> +++ src/libCom/osi/os/WIN32/osdThread.c 2012-06-15 18:40:04 +0000
> @@ -779,18 +779,15 @@
>      static const unsigned mSecPerSec = 1000;
>      DWORD milliSecDelay;
> -    if ( seconds <= 0.0 ) {
> +    if ( seconds > 0.0 ) {
> +        seconds *= mSecPerSec;
> +        milliSecDelay = ( seconds >= INFINITE ) ?
> +            INFINITE - 1 : ( DWORD ) seconds;
>          milliSecDelay = 0u;
> -    else if ( seconds >= INFINITE / mSecPerSec ) {
> -        milliSecDelay = INFINITE - 1;
> -    else {
> -        milliSecDelay = ( DWORD ) ( ( seconds * mSecPerSec ) + 0.5 );
> -        if ( milliSecDelay == 0 ) {
> -            milliSecDelay = 1;
>      Sleep ( milliSecDelay );
> === modified file 'src/libCom/osi/os/posix/osdThread.c'
> --- src/libCom/osi/os/posix/osdThread.c 2012-02-03 00:14:01 +0000
> +++ src/libCom/osi/os/posix/osdThread.c 2012-06-15 20:36:21 +0000
> @@ -673,9 +673,15 @@
>      struct timespec remainingTime;
>      double nanoseconds;
> -    delayTime.tv_sec = (time_t)seconds;
> -    nanoseconds = (seconds - (double)delayTime.tv_sec) *1e9;
> -    delayTime.tv_nsec = (long)nanoseconds;
> +    if (seconds > 0) {
> +        delayTime.tv_sec = seconds;
> +        nanoseconds = (seconds - delayTime.tv_sec) *1e9;
> +        delayTime.tv_nsec = nanoseconds;
> +    else {
> +        delayTime.tv_sec = 0;
> +        delayTime.tv_nsec = 0;
>      while (nanosleep(&delayTime, &remainingTime) == -1 &&
>             errno == EINTR)
>          delayTime = remainingTime;
> === modified file 'src/libCom/osi/os/vxWorks/osdThread.c'
> --- src/libCom/osi/os/vxWorks/osdThread.c       2010-08-11 15:45:17 +0000
> +++ src/libCom/osi/os/vxWorks/osdThread.c       2012-06-15 20:52:58 +0000
> @@ -18,6 +18,7 @@
>  #include <stdlib.h>
>  #include <stddef.h>
>  #include <stdio.h>
>  #include <vxWorks.h>
>  #include <taskLib.h>
> @@ -279,11 +280,13 @@
>      STATUS status;
>      int ticks;
> -    if(seconds<=0.0) {
> +        seconds *= sysClkRateGet();
> +        ticks = (seconds >= INT_MAX) ? INT_MAX : (int) seconds;
>          ticks = 0;
> -    } else {
> -        ticks = seconds*sysClkRateGet() + 0.5;
> -        if(ticks<=0) ticks = 1;
>      status = taskDelay(ticks);
>      if(status) errlogPrintf("epicsThreadSleep\n");
> - Andrew
> Never interrupt your enemy when he is making a mistake.
> -- Napoleon Bonaparte
timer delay compensation Hill, Jeff
Re: timer delay compensation Eric Norum
Re: timer delay compensation Ralph Lange
Re: timer delay compensation Andrew Johnson
Prev: Re: timer delay compensation Andrew Johnson
Next: Re: [Merge] lp:~epics-core/epics-base/server-side-plugins into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: timer delay compensation Andrew Johnson
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
