2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: timer delay compensation
To: <[email protected]>
Date: Thu, 14 Jun 2012 12:58:16 +0200
On Thursday, June 14, 2012, Ralph Lange wrote:
> On 14.06.2012 04:19, Eric Norum wrote:
> > I think that epicsThreadSleep(x) should guarantee to return only after
> > at least x seconds have elapsed. This is in line with the semantics of
> > every other implementation of similar functions of which I'm aware.
> And it does!
> There are two separate issues.
> 1) Jeff's C++ epicsTimer compensates by subtracting half a quantum.
> IMHO, this API should be changed to that the client can select between
> "round-up" and "round" behavior, making "round-up" the default. As an
> API change, that should go to 3.15
For 3.14 we could offer "round up" as a non-default option. But this is not
essential, as this behaviour can be had by adding 0.5 to the delay.
> Jeff is right that I do not like the idea of changing the rounding
> behavior over the range of possible delays. That would obscure the spec,
> confuse the user, and introduce OS-implementation dependent behavior in
> the OS-independent part of libCom.
+1
> I'd rather let 3.14 live with the
> current state, and document it.
> 2) Some (=many) epicsThreadSleep(x) implementations do not work as
> defined and advertised, by calling the OS for a 1-quantum sleep even for
> a requested sleep of zero. Making the behavior consistent and to spec is
> a fix that goes into 3.14 and up.
+1
> Note that 2) does not make epicsThreadSleep(x) return early!
To clarify: it will return earlier than it does now, but not earlier than
specified.
Just my 2 cents.
Cheers
Ben
Attachment: signature.asc
Description: This is a digitally signed message part.
timer delay compensation Hill, Jeff
Re: timer delay compensation Eric Norum
Re: timer delay compensation Ralph Lange
Prev: Re: timer delay compensation Ralph Lange
Next: Re: timer delay compensation Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
