2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: timer delay compensation
To: "Hill, Jeff" <[email protected]>
Date: Wed, 13 Jun 2012 19:19:22 -0700
I think that epicsThreadSleep(x) should guarantee to return only after at least x seconds have elapsed.
This is in line with the semantics of every other implementation of similar functions of which I'm aware.
On Jun 13, 2012, at 6:12 PM, Hill, Jeff wrote:
> Hi Andrew, Ralph,
> We will need to decide how to proceed with the timer delay
> compensation issue. I am extremely busy so it will be easy
> for this to fall through the cracks.
> It occurs to me that this issue could also be fixed by just not
> compensating the timer delay when the requested delay is less than one
> quantum, but otherwise leaving the compensation code in place. I think
> I mentioned that option before, but I suspect that Ralph is in favor only
> of a solution that 100% removes the compensation. I mention this
> option again only because it would be easier to justify as a backwards
> compatible bug fix, and therefore as an R3.14 patch. I believe that
> Andrew is not in favor of a change that removes the compensation 100%
> from R3.14, and would postpone that change to R3.15.
> What do you think? I am happy to implement whatever the community
> consensus is.
> Jeff
Eric Norum
[email protected]
Re: timer delay compensation Ralph Lange
timer delay compensation Hill, Jeff
Prev: timer delay compensation Hill, Jeff
Next: Re: timer delay compensation Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
