g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: timer delay compensation
To: Ralph Lange <Ralph.Lange@gmx.de>, Andrew Johnson <anj@aps.anl.gov>
Cc: "core-talk@aps.anl.gov" <core-talk@aps.anl.gov>
Date: Thu, 14 Jun 2012 01:12:42 +0000
Hi Andrew, Ralph,
We will need to decide how to proceed with the timer delay
compensation issue. I am extremely busy so it will be easy
for this to fall through the cracks.
It occurs to me that this issue could also be fixed by just not
compensating the timer delay when the requested delay is less than one
quantum, but otherwise leaving the compensation code in place. I think
I mentioned that option before, but I suspect that Ralph is in favor only
of a solution that 100% removes the compensation. I mention this
option again only because it would be easier to justify as a backwards
compatible bug fix, and therefore as an R3.14 patch. I believe that
Andrew is not in favor of a change that removes the compensation 100%
from R3.14, and would postpone that change to R3.15.
What do you think? I am happy to implement whatever the community
consensus is.
Jeff
Re: timer delay compensation Eric Norum
Prev: Re: "spinlock" API Andrew Johnson
Next: Re: timer delay compensation Eric Norum
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
