So what what's your recommendation for an RTEMS implementation of epicsThreadSleep? Constraints: - Minimize floating point - Don't make delays longer than necessary. I'd expand your "0.0 doesn't sleep one quantum" to "epicsThreadSleep(N*epicsThreadSleepQuantum()) should call the underlying OS delay routine for a N-tick delay -- not N+1 ticks".
On Jun 8, 2012, at 8:04 AM, Ralph Lange wrote:
IMHO:
1. epicsTimer should not round.
2. epicsThreadSleep should always round up, following usual
sleep/pause/nap/delay semantics, without forcing a sleep of one
quantum when 0.0 is requested.
This matches the existing API specification. Currently, Windows,
vxWorks, and RTEMS implementations do not follow the API spec, the
posic implementation is correct.
2. The epicsTimer behaviour should be documented.
3. An application that wants statistically optimized delays may
subtract half a quantum when setting up the epicsTimer. This should
be mentioned in the documentation, and scan threads, ca beacons etc.
should use this method. (Maybe add a "statistically more accurate"
variant of the start method to the epicsTimer API for convenience.)
Cheers,
Ralph
- Re: epicsTimer and rounding Eric Norum
- epicsTimer and rounding Ralph Lange
- RE: epicsTimer and rounding Hill, Jeff
- Re: epicsTimer and rounding Ralph Lange
Re: epicsTimer and rounding Andrew Johnson
<2012>
<2012>
ANJ, 26 Nov 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
