g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Re: [Merge] lp:~johill-lanl/epics-base/epicsThreadOnce-atomics-based into lp:epics-base
To: Jeff Hill <johill@lanl.gov>
Date: Mon, 04 Jun 2012 17:58:26 -0000
Review: Needs Fixing
Hi Jeff,
The epicsThreadOnce.cpp file has an essential function epicsThreadOnceOnly() which calls cantProceed(), epicsThreadSleep() and errlogPrintf() [the cantProceed() function also calls both of the other two].  Unfortunately both the errlog and generalTime facilities rely on epicsThreadOnce during initialization, thus this implementation could be subject to circular startup problems.
When I try to boot an IOC on vxWorks 6.8 with this code, it hangs silently while executing the C++ static constructors.
If I replace the errlogPrintf() call with std::printf(), after maybe a 10 second delay waiting for the vxWorks munch file to finish loading I get the message "epicsThreadOnce: waiting for another thread to finish calling the once function" which then repeats forever.  Here's the stack of the thread loading the munch file:
0x00206b2c ld           +0xb4 : usrModuleLoad ()
0x002069e0 usrModuleLoad+0x1c : loadModule ()
0x001da4c0 loadModule   +0x24 : loadModuleAt ()
0x001da3d4 loadModuleAt +0xe0 : 0x001da02c ()
0x001da198 loadLibInit  +0x21c: cplusLoadFixup ()
0x002141a4 cplusLoadFixup+0x8c : cplusCallCtors ()
0x00143594 cplusCallCtors+0x28 : _GLOBAL__I_iocshPpdbbase ()
0x010b2bc8 _GLOBAL__I_iocshPpdbbase+0x28 : 0x010b2ae8 ()
0x010b2b44 iocshRegister+0x210: iocshRegister ()
0x010b2978 iocshRegister+0x44 : 0x010b0d40 ()
0x010b0d70 gphInitPvt   +0x16c: epicsThreadOnce ()
0x010bdfc4 epicsThreadOnce+0xfc : 0x010c59bc (0x8000003c)
0x010c5a44 epicsThreadSleep+0x8c : taskDelay ()
I suspect it may not be possible to fix this in a generic, portable fashion. The current implementations of epicsThreadOnce() are all OS-specific and understand the OS-specific startup requirements.  However I'd be happy to test a revised version if you manage to get it working properly on vxWorks.
- Andrew
https://code.launchpad.net/~johill-lanl/epics-base/epicsThreadOnce-atomics-based/+merge/73606
Your team EPICS Core Developers is subscribed to branch lp:~epics-core/epics-base/epicsR3.15-atomics.
Prev: Re: [Merge] lp:~epics-core/epics-base/msi-join into lp:epics-base Andrew Johnson
Next: [Merge] lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: [Merge] lp:~epics-core/epics-base/msi-join into lp:epics-base noreply
Next: [Merge] lp:~mdavidsaver/epics-base/epicsconf into lp:epics-base/3.14 Andrew Johnson
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
