On 5/30/2012 11:29 AM, Andrew Johnson wrote:
Ralph's server side plugins work. The remaining work is to figure out
how best to run the unit tests on RTEMS and vxWorks.
https://code.launchpad.net/~epics-core/epics-base/server-side-plugins
I added the necessary test harness files to the src/ioc/db/test directory on
the 3.15 branch yesterday. We will probably have to make some changes to the
tests to ensure that they can all be run within the same process image though
(you can only run iocInit once); I haven't looked at the tests so this might
need some creativity...
I imagine this will be tricky. There is only one test which runs
iocInit. However several tests load and free a database.
And if I have time
https://code.launchpad.net/~epics-core/epics-base/callback-error
Although I think I will make some changes to this as well. I'm having
second thoughts about adding a field to the CALLBACK structure which
existing code may not initialize correctly.
If the user's source code needs to be changed you should ensure that the
compiler aborts with an error if they haven't made that change. This is how
we handled similar API changes between 3.13 and 3.14.
Yes, I consider this a requirement as well. However, I don't think
there is a way to do this without effectively breaking all usage of
CALLBACK. The issue is that users are allowed to embedded these
structures directly and there has been no official way to initialize
them. I can't think of a nice way of enforcing the use of memset() or
similar.
Michael
- R3.15.0 deadline approaching Andrew Johnson
- Re: R3.15.0 deadline approaching Michael Davidsaver
- Re: R3.15.0 deadline approaching Andrew Johnson
Re: R3.15.0 deadline approaching J. Lewis Muir
[Merge] lp:~epics-core/epics-base/server-side-plugins into lp:epics-base mdavidsaver
<2012>
<2012>
