g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: Problem installing EPICS QT Client
From: manta santosh aditya santosh_aditya <santosh_aditya@ecil.co.in>
To: core-talk@aps.anl.gov
Date: Mon, 14 May 2012 14:00:24 +0530 (IST)
i tried installin EPICS QT but i got the following error.
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `epicsMutexUnlock'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `QwtPlot::insertLegend(QwtLegend*, QwtPlot::LegendPosition, double)'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `QwtPlot::setAxisScale(int, double, double, double)'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `ca_name'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `epicsEventSignal'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `QwtPlot::axisTitle(int) const'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `QwtPlotGrid::setMinPen(QPen const&)'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `QwtText::text() const'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `epicsMutexOsiCreate'
/home/sssd/Documents/epicsqt/ca_framework/plugins/libQCaPlugin.so: undefined reference to `ca_add_exception_event'
please help me in this regard
i have set QCAFRAMEWORK to /home/sssd/Documents/epicsqt/ca_framework
M SANTOSH ADITYA
SSSD, ECIL
Phone: 040-27182914, 040-27182977
"I cannot give you the formula for success, but I can give you the formula for failure--which is - Try to please everybody".
- Herbert Bayard Swope
::DISCLAIMER::
The contents of this e-mail and any attachment(s) are confidential and intended for the named recipient(s) only.
It shall not attach any liability on the originator or ECIL or its affiliates. Any views or opinions presented in
this email are solely those of the author and may not necessarily reflect the opinions of ECIL or its affiliates.
Any form of reproduction, dissemination, copying, disclosure, modification, distribution and / or publication of
this message without the prior written consent of the author of this e-mail is strictly prohibited. If you have
received this email in error please delete it and notify the sender immediately. Before opening any mail and
attachments please check them for viruses and defect.
THIS MAIL IS SCANNED BY ECIL IMSS FOR VIRUS AND SPAMS.
Re: Problem installing EPICS QT Client Andrew Johnson
Prev: [Merge] lp:~anj/epics-base/remove-hpux-artifacts into lp:epics-base Andrew Johnson
Next: Re: Problem installing EPICS QT Client Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Prev: [Merge] lp:~anj/epics-base/remove-hpux-artifacts into lp:epics-base noreply
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
