g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
Subject: DBF_STRING to DBF_ENUM/MENU/DEVICE Conversions
To: "EPICS core-talk" <core-talk@aps.anl.gov>
Date: Fri, 27 Jan 2012 12:08:49 -0600
To core-talk readers with opinions, please discuss the following.
Yesterday I responded to a bug report from Josh Stein on tech-talk about dbpf
not accepting integers when setting a bi.VAL field, which is a DBF_ENUM.  His
issue turned out to be an extraneous ! operator in the dbpf code (from a
refactoring of mine in about 2008) combined with what appears to be a bug in
the MinGW implementation of sscanf().  I posted a patch to the Known Problems
page which fixes dbpf and changes the STRING to ENUM/MENU/DEVICE conversion
routines, but I am not sure the latter changes are right.
Both dbConvert.c and dbFastLinkConv.c use the conversion string " %u %n" but
on MinGW sscanf() doesn't set the argument corresponding to the %n when there
are no spaces after the unsigned value in the string being converted.  The
space before the %u is unnecessary and can be safely removed since %u skips
leading white-space.  The space after the %u directive was included to skip
any trailing white-space.  The converters compare the value returned by the %n
directive with strlen() to make sure that only white-space characters follow
the number.
All of the other string to numeric conversion routines ignore any extraneous
characters that appear after the number.  I suspect the ENUM/MENU/DEVICE
conversions do not allow extraneous text to avoid the following, which happens
if I remove the %n and strlen() check from the current code to make these
match the other conversion routines:
epics> dbpf anjHost:bi.SCAN "5 seconds"
DBR_STRING:          "2 second"
This would obviously not be a good thing, so I have abandoned that idea.
The simple patch I posted yesterday changes the conversion format strings from
" %u %n" to "%u%n" which disallows trailing spaces completely (when putting
strings containing an integer to an ENUM/MENU/DEVICE field; other conversions
are not affected).  This changes the conversion behavior of the IOC subtly,
but I think it's acceptable.  Any other workaround for the MinGW sscanf()
problem will involve adding code to check for trailing spaces ourselves — not
hard, but a bit fiddly.
Does anyone object to the simple solution?
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
Prev: [Merge] lp:~jlmuir/epics-base/iocsh-comment-fix-3.14 into lp:epics-base/3.14 J. Lewis Muir
Next: [Merge] lp:~anj/epics-base/compiled-dbd into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  <20122013
ANJ, 26 Nov 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
