Subject: |
Re: [Merge] lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base |
"J. Lewis Muir" <jlmuir@anl.gov> |
To: |
Andrew Johnson <anj@aps.anl.gov> |
Date: |
Tue, 10 Jan 2012 15:31:30 -0000 |
> My first preference for a suitable language would be Lua since the licensing
> is suitable (MIT) and there is a glue layer available for running it on
> vxWorks which allows Lua scripts to call functions found through the vxWorks
> symbol table. It should be relatively easy to extend Lua to run registered
> iocsh commands as well.
Hi, Andrew.
I'd be fine with Lua, but someone has to do the work.
I have another idea: What if I changed the syntax of my proposed if-statement feature to match that of Lua? It would be way more restrictive than Lua, and I would likely have to chop some things out of it, but Lua would be a superset such that if someone did do the work to switch to Lua at a later time, existing scripts using my proposed if-statement would continue to work in Lua. Would that make this branch merge more likely?
Lewis
https://code.launchpad.net/~jlmuir/epics-base/iocsh-if-flow-control-3.14/+merge/87972
Your team EPICS Core Developers is requested to review the proposed merge of lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base.
- Re: [Merge] lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base Andrew Johnson
Re: [Merge] lp:~jlmuir/epics-base/iocsh-if-flow-control-3.14 into lp:epics-base J. Lewis Muir
<2012>
<2012>
