2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: extern "C" { #include <...> }
To: "Jeff Hill" <[email protected]>
Cc: "'EPICS core-talk'" <[email protected]>
Date: Fri, 9 Sep 2011 17:22:45 -0500
Hi Jeff,
On 2011-09-08 Jeff Hill wrote:
> Agree with Eric that it may very well be OS specific, and even OS version
> specific, whether the OS headers provide their own conditional blocks for
> C++ specifying extern "C", or not. It seems odd that it's that way for all
> OS. Could also simply have been a mistake, or a bad assumption at the time
> that it was written. I'm not sure what the standard says about nested
>  extern "C" blocks?
I'm guessing it used to be necessary on some OS, and that osdSock.h file got
copied to the other OSs.  I just committed the changes to delete these — I
tested it on many but not all so it's possible I might have broken something
which we can fix later if it comes up.
The problem with nesting extern "C" blocks is that the target has no way to
know if it's inside one, and even if you can say extern "C++" nobody does.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
extern "C" { #include <...> } Andrew Johnson
RE: extern "C" { #include <...> } Jeff Hill
Prev: Re: 3.14 branch broken for older vxWorks Andrew Johnson
Next: [Merge] lp:~epics-core/epics-base/rebased-atomics into lp:epics-base noreply
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: extern "C" { #include <...> } Jeff Hill
Next: RE: 3.14 branch broken for older vxWorks Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
