Subject: |
Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
Jeff Hill <[email protected]> |
Date: |
Thu, 01 Sep 2011 15:48:30 -0000 |
Hi Jeff,
On 2011-08-31 Jeff Hill wrote:
> your changes look good
Thanks.
> I suspect that you now see that I did implement a clang specific
> compilerDependent.h. I did include a #warning in that file because I don't
> yet have clang installed here and it hasn't been tested.
I removed it after testing on Linux, and I added a #error in the gcc-specific
header if it gets used by clang.
> I see that you added a commented out compiler class definition (which will
> cause the clang specific file to be used) for clang in multiple places.
> Perhaps we can conditionally include a clang specific configure file as we
> do with gcc so that this can be consolidated? The typical approach is to
> add a suffix to the arch - i.e. linux-x86-clang. That probably needs to be
> done, but it probably should be considered orthogonal to this merge
> proposal (I prefer not to block other layered merges)
You're probably right about adding *-x86-clang targets, although there may be
some complications on MacOS/X, see the discussion of gcc_select at
https://trac.macports.org/wiki/UsingTheRightCompiler
I'll talk to Janet about this.
> > Have you based your atomic branch on this one? I'd like to drop your
> > 12229 merge commit, but that would probably mess you up if I did.
Forget that idea of dropping 12229, it's not a problem.
I will try to merge this branch into lp:epics-base/3.15 today.
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
https://code.launchpad.net/~epics-core/epics-base/3.15-buildCompilerSpecific/+merge/72258
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base.
- Re: [Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base Jeff Hill
RE: Atomic operation library and spin-lock for the epics ring buffer Jeff Hill
[Merge] lp:~epics-core/epics-base/3.15-buildCompilerSpecific into lp:epics-base noreply
<2011>
<2011>
