2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base
To: Jeff Hill <[email protected]>
Date: Tue, 30 Aug 2011 23:22:23 -0000
Tested successfully on
cygwin-x86
win32-x86
win32-x86-mingw
windows-64
linux-x86
vxWorks-cRIO (this was ls vxWorks 6.2 with gcc 3 as I recall}
I also test the vxAtomicLib part of the vxWorks specific code code by temporarily disabling the gcc intrinsic implementation
I also ran this test.
vxWorks-ppc604 (this was vxWorks 6.8 with gcc 4)
When I run the atomic tests on vxWorks 6.8 their output, at the end, states "expected N tests, but 0 test were run" on vxWorks 6.8? I see the normal OK messages as the tests run? On vxWorks 6.2 the tests appear to run normally.
https://code.launchpad.net/~epics-core/epics-base/epicsR3.15-atomics/+merge/70642
Your team EPICS Core Developers is requested to review the proposed merge of lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base.
[Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Prev: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
Next: [Merge] lp:~johill-lanl/epics-base/epicsThreadOnce-atomics-based into lp:epics-base Jeff Hill
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: Re: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
Next: [Merge] lp:~epics-core/epics-base/epicsR3.15-atomics into lp:epics-base Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
