Hi Michael,
On 2011-06-17 Michael Davidsaver wrote:
> I'd like to add a standard 64-bit integer type to epicsTypes.h.
> Currently this is only available when compiling with the C99 extensions
> enabled.
> Attached are two proposed patches. The first adds sanity checks of the
> existing type sizes. The second defines epicsUInt64 and epicsInt64.
> The C primitive used (either long or long long) is chosen by testing the
> size of LONG_MAX. I think this should work for all toolchains which
> actually provide a 64-bit integer type. The question is, are there any
> which don't and need to be supported?
There were issues with using long long on some vxWorks versions/architectures,
although from what I can see they were only in vxWorks 5.3.x releases and the
later releases apparently do provide full support. I believe there were some
support routines that gcc calls implicitly which the OS relegated to an
external libgcc.a library rather than building them into the OS image.
I would suggest moving your verification code into libCom/test and adding a
test program to the file that exercises the basic operations +-*/&|^~ with the
epicsInt64 and epicsUInt64 types to ensure they are all implemented. The
tests in libCom/test are intended to help us confirm that the OS properly
implements all the facilities we need/expect.
Are you looking for this in 3.14.x or 3.15?
- Andrew
Optimization is the process of taking something that works and
replacing it with something that almost works, but costs less.
-- Roger Needham
- Re: 64 bit integers (aka. long or long long) Michael Davidsaver
- Re: 64 bit integers (aka. long or long long) Benjamin Franksen
- 64 bit integers (aka. long or long long) Michael Davidsaver
<2011>
<2011>
