2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base
Date: Fri, 25 Feb 2011 21:43:52 -0000
> I'm just talking about moving the directories libCom/tools/flex to
> libCom/flex, and libCom/tools/antelope to libCom/yacc, which I have now
> successfully done.
Ah, I mis-read your message.
> I had to rename the antelope directory to yacc since make
> thinks an antelope directory is the antelope target it's being asked to build
> and tries to install it as a script.
Hadn't thought of that...
> After also renaming the two main.c files
> to get everything to build properly I'm now up to your revid 12222.  I'm
> keeping the dependency resolution fix you described, and everything under
> libCom still builds in one go.
> I will record you as the author for these commits.
Not necessary.  Just be yourself ;)
https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src/+merge/44296
Your team EPICS Core Developers is requested to review the proposed merge of lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base.
Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
