2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base
To: mdavidsaver <[email protected]>
Date: Fri, 25 Feb 2011 21:37:02 -0000
I'm just talking about moving the directories libCom/tools/flex to libCom/flex, and libCom/tools/antelope to libCom/yacc, which I have now successfully done.  I had to rename the antelope directory to yacc since make thinks an antelope directory is the antelope target it's being asked to build and tries to install it as a script.  After also renaming the two main.c files to get everything to build properly I'm now up to your revid 12222.  I'm keeping the dependency resolution fix you described, and everything under libCom still builds in one go.  I will record you as the author for these commits.
https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src/+merge/44296
Your team EPICS Core Developers is requested to review the proposed merge of lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base.
Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
