g+
g+ Communities
Argonne National Laboratory
2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Subject: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base
To: mdavidsaver <mdavidsaver@bnl.gov>
Date: Fri, 25 Feb 2011 19:46:18 -0000
Hi Michael,
I'm currently working on merging your reorganization with my branch that split the libCom/Makefile into multiple fragments that are local to the source files but that get included by the original file.  I will repeat this idea in the other src/* directories, which I believe should also make it slightly easier to merge changes across this reorganization boundary.
Did you have any particular reason for putting antelope and flex under libCom/tools rather than directly under libCom?  I'm currently inclined to drop the tools layer.
- Andrew (from home, via LP)
https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src/+merge/44296
Your team EPICS Core Developers is requested to review the proposed merge of lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base.
Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base mdavidsaver
Prev: Re: [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base mdavidsaver
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013
Prev: [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base noreply
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
· EPICSv4 · IRMIS · Talk · Bugs · Documents · Links · Licensing ·
