Subject: |
Re: [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base |
Andrew Johnson <[email protected]> |
To: |
"EPICS core-talk" <[email protected]> |
Date: |
Wed, 9 Feb 2011 11:25:36 -0600 |
Hi Guys,
On Tuesday 08 February 2011 15:40:14 Andrew Johnson proposed merging
> lp:~anj/epics-base/epicsEvent-api into lp:epics-base.
> For more details, see:
> https://code.launchpad.net/~anj/epics-base/epicsEvent-api/+merge/48992
The main thing I'd like comments on are whether the old C++ signal() method
should throw an exception (which it didn't do before) or suspend the thread if
it gets an error. The new trigger() method does throw, while the original C
routine epicsEventSignal(id) suspends.
>From the Windows users out there, was this a bad thing to do:
> The epicsShareAPI decorations (used on Windows only) have all been removed.
IIUC that only matters if someone is tries to call epicsEvent routines from a
tool such as Visual Basic that only supports the old Pascal calling
conventions. I don't see that as a problem nowadays.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base Andrew Johnson
Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Andrew Johnson
<2011>
Re: [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base Andrew Johnson
<2011>
