Andrew Johnson has proposed merging lp:~anj/epics-base/epicsEvent-api into lp:epics-base.
Requested reviews:
EPICS Core Developers (epics-core)
For more details, see:
https://code.launchpad.net/~anj/epics-base/epicsEvent-api/+merge/48992
This branch modifies the epicsEvent APIs for both C and C++ callers, but keeping full backwards compatibility.
The enum epicsEventWaitStatus is renamed to epicsEventStatus, with similar name changes for the choices except for epicsEventWaitTimeout which is unchanged. Macros are provided to allow continued use of the old names.
It adds two new routines to the C API:
+ epicsEventTrigger(id) replaces epicsEventSignal(id) but returns an epicsEventStatus so it can flag any errors from the implementation routines.
+ epicsEventMustTrigger(id) calls epicsEventTrigger(id) and suspends the calling thread on error.
epicsEventSignal(id) is now a macro that calls epicsEventMustTrigger(id).
epicsEventWait() and epicsEventWaitWithTimeout() now report errors from the implementation on all architectures; previously some architectures would suspend the thread instead.
All the epicsEventMust...() routines are now implemented in the common epicsEvent.cpp source file, and properly call cantProceed() instead of mis-using assert() in the event of any errors.
The Posix implementation now provides a basic epicsEventShow() routine.
For the C++ API it adds an epicsEvent::trigger() method that will throw an epicsEvent::invalidSemaphore exception on receiving an error.
The epicsEvent::signal() method is now an inline call to epicsEvent::trigger(), although I wonder whether signal() should halt on error like it used to instead of throwing.
The epicsShareAPI decorations (used on Windows only) have all been removed.
Your team EPICS Core Developers is requested to review the proposed merge of lp:~anj/epics-base/epicsEvent-api into lp:epics-base.
=== modified file 'documentation/RELEASE_NOTES.html'
--- documentation/RELEASE_NOTES.html 2010-11-28 03:06:40 +0000
+++ documentation/RELEASE_NOTES.html 2011-02-08 21:39:58 +0000
@@ -13,6 +13,30 @@
<h2 align="center">Changes between 3.14.x and 3.15.1</h2>
<!-- Insert new items immediately below here ... -->
+<h3>
+Reworked the epicsEvent C & C++ APIs</h3>
+<ul>
+ <li>Renamed the enum epicsEventWaitStatus to epicsEventStatus</li>
+ <li>Defined epicsEventWaitStatus as a macro for epicsEventStatus</li>
+ <li>Renamed epicsEventWaitOk to epicsEventOk</li>
+ <li>Renamed epicsEventWaitError to epicsEventError</li>
+ <li>Defined epicsEventWaitOK and epicsEventWaitError as macros</li>
+ <li>Added epicsEventTrigger(id) which triggers an event and returns OK or an
+ error status if the underlying OS primitives report an error</li>
+ <li>Added epicsEventMustTrigger(id) which halts on error</li>
+ <li>Defined epicsEventSignal(id) as a macro for epicsEventMustTrigger(id)</li>
+ <li>Added a new C++ method epicsEvent::trigger() which throws an
+ epicsEvent::invalidSemaphore in the event of an error</li>
+ <li>epicsEvent::signal() makes an inline call to epicsEvent::trigger()</li>
+ <li>epicsEventWait() and epicsEventWaitWithTimeout() now return an error
+ status if the underlying OS primitives report an error</li>
+ <li>All the epicsEventMust...() routines are now implemented in the common
+ libCom/osi/epicsEvent.cpp source file, and call cantProceed() instead of
+ mis-using assert()</li>
+ <li>Implemented epicsEventShow() on Posix</li>
+ <li>Win32: Removed all epicsShareAPI decorations</li>
+</ul>
<h3>
Moved src/RTEMS/base directory</h3>
=== modified file 'src/libCom/osi/epicsEvent.cpp'
--- src/libCom/osi/epicsEvent.cpp 2004-09-30 19:15:45 +0000
+++ src/libCom/osi/epicsEvent.cpp 2011-02-08 21:39:58 +0000
@@ -1,10 +1,9 @@
-* Copyright (c) 2002 The University of Chicago, as Operator of Argonne
+* Copyright (c) 2011 UChicago Argonne LLC, as Operator of Argonne
* National Laboratory.
* Copyright (c) 2002 The Regents of the University of California, as
* Operator of Los Alamos National Laboratory.
-* EPICS BASE Versions 3.13.7
-* and higher are distributed subject to a Software License Agreement found
+* EPICS BASE is distributed subject to a Software License Agreement found
* in file LICENSE that is included with this distribution.
@@ -17,6 +16,7 @@
#define epicsExportSharedSymbols
#include "epicsEvent.h"
#include "epicsStdioRedirect.h"
+#include "cantProceed.h"
// vxWorks 5.4 gcc fails during compile when I use std::exception
using namespace std;
@@ -52,49 +52,81 @@
epicsEventDestroy ( this->id );
-void epicsEvent::signal ()
+void epicsEvent::trigger ()
- epicsEventSignal ( this->id );
+ epicsEventStatus status = epicsEventTrigger (this->id);
+ if (status != epicsEventOK) {
+ throw invalidSemaphore ();
void epicsEvent::wait ()
- epicsEventWaitStatus status;
- status = epicsEventWait (this->id);
- if (status!=epicsEventWaitOK) {
+ epicsEventStatus status = epicsEventWait (this->id);
bool epicsEvent::wait (double timeOut)
- status = epicsEventWaitWithTimeout (this->id, timeOut);
- if (status==epicsEventWaitOK) {
+ epicsEventStatus status = epicsEventWaitWithTimeout (this->id, timeOut);
+ if (status == epicsEventOK) {
return true;
- } else if (status==epicsEventWaitTimeout) {
+ } else if (status == epicsEventWaitTimeout) {
return false;
- } else {
- throw invalidSemaphore ();
- return false;
bool epicsEvent::tryWait ()
- status = epicsEventTryWait (this->id);
+ epicsEventStatus status = epicsEventTryWait (this->id);
return true;
return false;
- } else {
- return false;
void epicsEvent::show ( unsigned level ) const
epicsEventShow ( this->id, level );
+// epicsEventMust... convenience routines for C code
+extern "C" {
+epicsShareFunc epicsEventId epicsEventMustCreate (
+ epicsEventInitialState initialState)
+ epicsEventId id = epicsEventCreate (initialState);
+ if (!id)
+ cantProceed ("epicsEventMustCreate");
+ return id;
+epicsShareFunc void epicsEventMustTrigger (epicsEventId id) {
+ epicsEventStatus status = epicsEventTrigger (id);
+ cantProceed ("epicsEventMustTrigger");
+epicsShareFunc void epicsEventMustWait (epicsEventId id) {
+ epicsEventStatus status = epicsEventWait (id);
+ cantProceed ("epicsEventMustWait");
+} // extern "C"
=== modified file 'src/libCom/osi/epicsEvent.h'
--- src/libCom/osi/epicsEvent.h 2009-01-06 17:07:56 +0000
+++ src/libCom/osi/epicsEvent.h 2011-02-08 21:39:58 +0000
@@ -1,25 +1,33 @@
#ifndef epicsEventh
#define epicsEventh
-#include "epicsAssert.h"
#include "shareLib.h"
typedef struct epicsEventOSD *epicsEventId;
typedef enum {
- epicsEventWaitOK,epicsEventWaitTimeout,epicsEventWaitError
-} epicsEventWaitStatus;
-typedef enum {epicsEventEmpty,epicsEventFull} epicsEventInitialState;
+ epicsEventOK = 0,
+ epicsEventWaitTimeout,
+ epicsEventError
+} epicsEventStatus;
+/* Backwards compatibility */
+#define epicsEventWaitStatus epicsEventStatus
+#define epicsEventWaitOK epicsEventOK
+#define epicsEventWaitError epicsEventError
+typedef enum {
+ epicsEventEmpty,
+ epicsEventFull
+} epicsEventInitialState;
#ifdef __cplusplus
@@ -27,42 +35,40 @@
public:
epicsEvent ( epicsEventInitialState initial = epicsEventEmpty );
~epicsEvent ();
- void signal ();
- void wait (); /* blocks until full */
- bool wait ( double timeOut ); /* false if empty at time out */
- bool tryWait (); /* false if empty */
+ void trigger ();
+ void signal () { this->trigger(); }
+ void wait (); /* blocks until full */
+ bool wait ( double timeOut ); /* false if still empty at time out */
+ bool tryWait (); /* false if empty */
void show ( unsigned level ) const;
- class invalidSemaphore; /* exception payload */
+ class invalidSemaphore; /* exception payload */
private:
epicsEvent ( const epicsEvent & );
epicsEvent & operator = ( const epicsEvent & );
epicsEventId id;
-#endif /*__cplusplus */
-#ifdef __cplusplus
extern "C" {
-epicsShareFunc epicsEventId epicsShareAPI epicsEventCreate(
- epicsEventInitialState initialState);
-epicsShareFunc epicsEventId epicsShareAPI epicsEventMustCreate (
-epicsShareFunc void epicsShareAPI epicsEventDestroy(epicsEventId id);
-epicsShareFunc void epicsShareAPI epicsEventSignal(epicsEventId id);
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventWait(
- epicsEventId id);
-#define epicsEventMustWait(ID) { \
- epicsEventWaitStatus status = epicsEventWait(ID); \
- assert(status == epicsEventWaitOK); \
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventWaitWithTimeout(
+epicsShareFunc epicsEventId epicsEventCreate(
+ epicsEventInitialState initialState);
+epicsShareFunc void epicsEventDestroy(epicsEventId id);
+epicsShareFunc epicsEventStatus epicsEventTrigger(
+ epicsEventId id);
+epicsShareFunc void epicsEventMustTrigger(epicsEventId id);
+#define epicsEventSignal(ID) epicsEventMustTrigger(ID)
+epicsShareFunc epicsEventStatus epicsEventWait(
+ epicsEventId id);
+epicsShareFunc void epicsEventMustWait(epicsEventId id);
+epicsShareFunc epicsEventStatus epicsEventWaitWithTimeout(
epicsEventId id, double timeOut);
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventTryWait(
+epicsShareFunc epicsEventStatus epicsEventTryWait(
epicsEventId id);
-epicsShareFunc void epicsShareAPI epicsEventShow(
+epicsShareFunc void epicsEventShow(
epicsEventId id, unsigned int level);
#ifdef __cplusplus
=== modified file 'src/libCom/osi/os/RTEMS/osdEvent.c'
--- src/libCom/osi/os/RTEMS/osdEvent.c 2010-10-05 19:27:37 +0000
+++ src/libCom/osi/os/RTEMS/osdEvent.c 2011-02-08 21:39:58 +0000
@@ -1,7 +1,8 @@
* Copyright (c) 2002 The University of Saskatchewan
+* National Laboratory.
@@ -18,7 +19,6 @@
#define __RTEMS_VIOLATE_KERNEL_VISIBILITY__ 1
-#include <assert.h>
#include <stdio.h>
#include <rtems.h>
#include <rtems/error.h>
@@ -84,13 +84,6 @@
return (epicsEventId)sid;
-epicsEventId epicsEventMustCreate(epicsEventInitialState initialState)
- epicsEventId id = epicsEventCreate (initialState);
- assert (id);
- return id;
void
@@ -102,18 +95,20 @@
errlogPrintf ("Can't destroy semaphore: %s\n", rtems_status_text (sc));
-void
-epicsEventSignal(epicsEventId id)
+epicsEventStatus
+epicsEventTrigger(epicsEventId id)
rtems_id sid = (rtems_id)id;
rtems_status_code sc;
sc = rtems_semaphore_release (sid);
- if (sc != RTEMS_SUCCESSFUL)
- errlogPrintf ("Can't release semaphore: %s\n", rtems_status_text (sc));
+ if (sc == RTEMS_SUCCESSFUL)
+ return epicsEventOK;
+ errlogPrintf ("Can't release semaphore: %s\n", rtems_status_text (sc));
+ return epicsEventError;
-epicsEventWaitStatus
+epicsEventStatus
epicsEventWait(epicsEventId id)
@@ -122,11 +117,11 @@
SEMSTAT(0)
sc = rtems_semaphore_obtain (sid, RTEMS_WAIT, RTEMS_NO_TIMEOUT);
- return epicsEventWaitError;
- return epicsEventWaitOK;
+epicsEventStatus
epicsEventWaitWithTimeout(epicsEventId id, double timeOut)
@@ -142,14 +137,14 @@
delay++;
sc = rtems_semaphore_obtain (sid, RTEMS_WAIT, delay);
else if (sc == RTEMS_TIMEOUT)
return epicsEventWaitTimeout;
else
+epicsEventStatus
epicsEventTryWait(epicsEventId id)
@@ -158,11 +153,11 @@
SEMSTAT(2)
sc = rtems_semaphore_obtain (sid, RTEMS_NO_WAIT, RTEMS_NO_TIMEOUT);
else if (sc == RTEMS_UNSATISFIED)
else
void
=== modified file 'src/libCom/osi/os/WIN32/osdEvent.c'
--- src/libCom/osi/os/WIN32/osdEvent.c 2010-10-05 19:27:37 +0000
+++ src/libCom/osi/os/WIN32/osdEvent.c 2011-02-08 21:39:58 +0000
@@ -1,10 +1,9 @@
/* osdEvent.c */
@@ -27,7 +26,6 @@
typedef struct epicsEventOSD {
HANDLE handle;
@@ -36,7 +34,7 @@
* epicsEventCreate ()
-epicsShareFunc epicsEventId epicsShareAPI epicsEventCreate (
+epicsShareFunc epicsEventId epicsEventCreate (
epicsEventInitialState initialState )
epicsEventOSD *pSem;
@@ -54,54 +52,43 @@
- * epicsEventMustCreate ()
- epicsEventInitialState initialState )
- epicsEventId id = epicsEventCreate ( initialState );
- assert ( id );
- return id;
* epicsEventDestroy ()
-epicsShareFunc void epicsShareAPI epicsEventDestroy ( epicsEventId pSem )
+epicsShareFunc void epicsEventDestroy ( epicsEventId pSem )
CloseHandle ( pSem->handle );
free ( pSem );
- * epicsEventSignal ()
+ * epicsEventTrigger ()
-epicsShareFunc void epicsShareAPI epicsEventSignal ( epicsEventId pSem )
+epicsShareFunc epicsEventStatus epicsEventTrigger ( epicsEventId pSem )
BOOL status;
status = SetEvent ( pSem->handle );
- assert ( status );
+ return status ? epicsEventOK : epicsEventError;
* epicsEventWait ()
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventWait ( epicsEventId pSem )
+epicsShareFunc epicsEventStatus epicsEventWait ( epicsEventId pSem )
DWORD status;
status = WaitForSingleObject (pSem->handle, INFINITE);
if ( status == WAIT_OBJECT_0 ) {
else {
* epicsEventWaitWithTimeout ()
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventWaitWithTimeout (
+epicsShareFunc epicsEventStatus epicsEventWaitWithTimeout (
epicsEventId pSem, double timeOut )
static const unsigned mSecPerSec = 1000;
@@ -122,38 +109,38 @@
status = WaitForSingleObject ( pSem->handle, tmo );
else if ( status == WAIT_TIMEOUT ) {
else {
* epicsEventTryWait ()
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventTryWait ( epicsEventId pSem )
+epicsShareFunc epicsEventStatus epicsEventTryWait ( epicsEventId pSem )
DWORD status;
status = WaitForSingleObject ( pSem->handle, 0 );
else {
* epicsEventShow ()
-epicsShareFunc void epicsShareAPI epicsEventShow ( epicsEventId id, unsigned level )
+epicsShareFunc void epicsEventShow ( epicsEventId id, unsigned level )
=== modified file 'src/libCom/osi/os/posix/osdEvent.c'
--- src/libCom/osi/os/posix/osdEvent.c 2009-04-23 18:49:40 +0000
+++ src/libCom/osi/os/posix/osdEvent.c 2011-02-08 21:39:58 +0000
@@ -1,5 +1,5 @@
-* Copyright (c) 2009 UChicago Argonne LLC, as Operator of Argonne
@@ -21,155 +21,142 @@
-#include "cantProceed.h"
#include "epicsTime.h"
#include "errlog.h"
/* Until these can be demonstrated to work leave them undefined*/
#undef _POSIX_THREAD_PROCESS_SHARED
#undef _POSIX_THREAD_PRIO_INHERIT
-typedef struct epicsEventOSD {
- pthread_mutex_t mutex;
- pthread_cond_t cond;
- int isFull;
-}epicsEventOSD;
-#define checkStatus(status,message) \
-if((status)) { \
- errlogPrintf("epicsEvent %s failed: error %s\n",(message),strerror((status)));}
-#define checkStatusQuit(status,message,method) \
-if(status) { \
- errlogPrintf("epicsEvent %s failed: error %s\n",(message),strerror((status))); \
- cantProceed((method)); \
-static int mutexLock(pthread_mutex_t *id)
- int status;
- while(1) {
- status = pthread_mutex_lock(id);
- if(status!=EINTR) return status;
- errlogPrintf("pthread_mutex_lock returned EINTR. Violates SUSv3\n");
-static int condTimedwait(pthread_cond_t *condId, pthread_mutex_t *mutexId,
- struct timespec *time)
- int status;
- while(1) {
- status = pthread_cond_timedwait(condId,mutexId,time);
- errlogPrintf("pthread_cond_timedwait returned EINTR. Violates SUSv3\n");
-static int condWait(pthread_cond_t *condId, pthread_mutex_t *mutexId)
- int status;
- while(1) {
- status = pthread_cond_wait(condId,mutexId);
- errlogPrintf("pthread_cond_wait returned EINTR. Violates SUSv3\n");
-epicsShareFunc epicsEventId epicsShareAPI epicsEventCreate(epicsEventInitialState initialState)
- epicsEventOSD *pevent;
- int status;
- pevent = callocMustSucceed(1,sizeof(*pevent),"epicsEventCreate");
- status = pthread_mutex_init(&pevent->mutex,0);
- checkStatusQuit(status,"pthread_mutex_init","epicsEventCreate");
- status = pthread_cond_init(&pevent->cond,0);
- checkStatusQuit(status,"pthread_cond_init","epicsEventCreate");
- if(initialState==epicsEventFull) pevent->isFull = 1;
- return((epicsEventId)pevent);
-epicsShareFunc epicsEventId epicsShareAPI epicsEventMustCreate(epicsEventInitialState initialState)
- assert (id);
- return id;
-epicsShareFunc void epicsShareAPI epicsEventDestroy(epicsEventId pevent)
- int status;
- status = pthread_mutex_destroy(&pevent->mutex);
- checkStatus(status,"pthread_mutex_destroy");
+struct epicsEventOSD {
+ pthread_mutex_t mutex;
+ pthread_cond_t cond;
+ int isFull;
+#define printStatus(status, routine, func) \
+ errlogPrintf("%s: %s failed: %s\n", (func), (routine), strerror(status))
+#define checkStatus(status, routine, func) \
+ if (status) { \
+ printStatus(status, routine, func); \
+#define checkStatusReturn(status, routine, func) \
+ if (status) { \
+ return epicsEventError; \
+epicsShareFunc epicsEventId epicsEventCreate(epicsEventInitialState init)
+ epicsEventId pevent = malloc(sizeof(*pevent));
+ if (pevent) {
+ int status = pthread_mutex_init(&pevent->mutex, 0);
+ pevent->isFull = (init == epicsEventFull);
+ if (status) {
+ printStatus(status, "pthread_mutex_init", "epicsEventCreate");
+ } else {
+ status = pthread_cond_init(&pevent->cond, 0);
+ if (!status)
+ return pevent;
+ printStatus(status, "pthread_cond_init", "epicsEventCreate");
+ status = pthread_mutex_destroy(&pevent->mutex);
+ checkStatus(status, "pthread_mutex_destroy", "epicsEventCreate");
+ free(pevent);
+ return NULL;
+epicsShareFunc void epicsEventDestroy(epicsEventId pevent)
+ int status = pthread_mutex_destroy(&pevent->mutex);
+ checkStatus(status, "pthread_mutex_destroy", "epicsEventDestroy");
status = pthread_cond_destroy(&pevent->cond);
- checkStatus(status,"pthread_cond_destroy");
+ checkStatus(status, "pthread_cond_destroy", "epicsEventDestroy");
free(pevent);
-epicsShareFunc void epicsShareAPI epicsEventSignal(epicsEventId pevent)
+epicsShareFunc epicsEventStatus epicsEventTrigger(epicsEventId pevent)
- int status;
+ int status = pthread_mutex_lock(&pevent->mutex);
- status = mutexLock(&pevent->mutex);
- checkStatusQuit(status,"pthread_mutex_lock","epicsEventSignal");
- if(!pevent->isFull) {
+ checkStatusReturn(status, "pthread_mutex_lock", "epicsEventTrigger");
+ if (!pevent->isFull) {
pevent->isFull = 1;
status = pthread_cond_signal(&pevent->cond);
- checkStatus(status,"pthread_cond_signal");
- status = pthread_mutex_unlock(&pevent->mutex);
- checkStatusQuit(status,"pthread_mutex_unlock","epicsEventSignal");
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventWait(epicsEventId pevent)
- int status;
- if(!pevent) return(epicsEventWaitError);
- checkStatusQuit(status,"pthread_mutex_lock","epicsEventWait");
- /*no need for while since caller must be prepared for no work*/
- status = condWait(&pevent->cond,&pevent->mutex);
- checkStatusQuit(status,"pthread_cond_wait","epicsEventWait");
- pevent->isFull = 0;
- checkStatusQuit(status,"pthread_mutex_unlock","epicsEventWait");
- return(epicsEventWaitOK);
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventWaitWithTimeout(epicsEventId pevent, double timeout)
- struct timespec wakeTime;
- int status = 0;
- int unlockStatus;
- checkStatusQuit(status,"pthread_mutex_lock","epicsEventWaitWithTimeout");
- convertDoubleToWakeTime(timeout,&wakeTime);
- status = condTimedwait(
- &pevent->cond,&pevent->mutex,&wakeTime);
- if(status==0) pevent->isFull = 0;
- unlockStatus = pthread_mutex_unlock(&pevent->mutex);
- checkStatusQuit(unlockStatus,"pthread_mutex_unlock","epicsEventWaitWithTimeout");
- if(status==0) return(epicsEventWaitOK);
- if(status==ETIMEDOUT) return(epicsEventWaitTimeout);
- checkStatus(status,"pthread_cond_timedwait");
- return(epicsEventWaitError);
-epicsShareFunc epicsEventWaitStatus epicsShareAPI epicsEventTryWait(epicsEventId id)
- return(epicsEventWaitWithTimeout(id,0.0));
-epicsShareFunc void epicsShareAPI epicsEventShow(epicsEventId id,unsigned int level)
+ checkStatus(status, "pthread_cond_signal", "epicsEventTrigger");
+ status = pthread_mutex_unlock(&pevent->mutex);
+ checkStatusReturn(status, "pthread_mutex_unlock", "epicsEventTrigger");
+epicsShareFunc epicsEventStatus epicsEventWait(epicsEventId pevent)
+ epicsEventStatus result = epicsEventOK;
+ checkStatusReturn(status, "pthread_mutex_lock", "epicsEventWait");
+ while (!pevent->isFull) {
+ status = pthread_cond_wait(&pevent->cond, &pevent->mutex);
+ if (status) {
+ printStatus(status, "pthread_cond_wait", "epicsEventWait");
+ result = epicsEventError;
+ goto release;
+ pevent->isFull = 0;
+ result = epicsEventOK;
+release:
+ checkStatusReturn(status, "pthread_mutex_unlock", "epicsEventWait");
+ return result;
+epicsShareFunc epicsEventStatus epicsEventWaitWithTimeout(epicsEventId pevent,
+ double timeout)
+ checkStatusReturn(status, "pthread_mutex_lock", "epicsEventWaitWithTimeout");
+ struct timespec wakeTime;
+ convertDoubleToWakeTime(timeout, &wakeTime);
+ while (!status && !pevent->isFull) {
+ status = pthread_cond_timedwait(&pevent->cond, &pevent->mutex,
+ &wakeTime);
+ if (status) {
+ result = (status == ETIMEDOUT) ?
+ epicsEventWaitTimeout : epicsEventError;
+ goto release;
+release:
+ checkStatusReturn(status, "pthread_mutex_unlock", "epicsEventWaitWithTimeout");
+ return result;
+epicsShareFunc epicsEventStatus epicsEventTryWait(epicsEventId id)
+ return epicsEventWaitWithTimeout(id, 0.0);
+epicsShareFunc void epicsEventShow(epicsEventId pevent, unsigned int level)
+ printf("epicsEvent %p: %s\n", pevent,
+ pevent->isFull ? "full" : "empty");
+ if (level > 0)
+ printf(" pthread_mutex = %p, pthread_cond = %p\n",
+ &pevent->mutex, &pevent->cond);
=== modified file 'src/libCom/osi/os/vxWorks/osdEvent.c'
--- src/libCom/osi/os/vxWorks/osdEvent.c 2008-09-24 19:24:59 +0000
+++ src/libCom/osi/os/vxWorks/osdEvent.c 2011-02-08 21:39:58 +0000
@@ -1,10 +1,9 @@
/* os/vxWorks/osdEvent.c */
@@ -29,19 +28,12 @@
(initialState == epicsEventEmpty) ? SEM_EMPTY : SEM_FULL);
- epicsEventId id = epicsEventCreate(initialState);
- assert(id);
- return id;
semDelete((SEM_ID)id);
-epicsEventWaitStatus epicsEventWaitWithTimeout(epicsEventId id, double timeOut)
+epicsEventStatus epicsEventWaitWithTimeout(epicsEventId id, double timeOut)
int rate = sysClkRateGet();
int status;
@@ -58,22 +50,22 @@
status = semTake((SEM_ID)id, ticks);
if (status == OK)
if (errno == S_objLib_OBJ_TIMEOUT ||
(errno == S_objLib_OBJ_UNAVAILABLE && ticks == 0))
-epicsEventWaitStatus epicsEventTryWait(epicsEventId id)
+epicsEventStatus epicsEventTryWait(epicsEventId id)
int status = semTake((SEM_ID)id, NO_WAIT);
if (status == OK)
if (errno == S_objLib_OBJ_UNAVAILABLE)
void epicsEventShow(epicsEventId id, unsigned int level)
=== modified file 'src/libCom/osi/os/vxWorks/osdEvent.h'
--- src/libCom/osi/os/vxWorks/osdEvent.h 2002-07-12 21:35:43 +0000
+++ src/libCom/osi/os/vxWorks/osdEvent.h 2011-02-08 21:39:58 +0000
@@ -1,10 +1,9 @@
/* os/vxWorks/osdEvent.h */
@@ -14,12 +13,8 @@
#include <vxWorks.h>
#include <semLib.h>
-/* If the macro is replaced by inline it is necessary to say
- static __inline__
- but then a warning message appears everywhere osdEvent.h is included
-#define epicsEventSignal(ID) semGive((SEM_ID)(ID))
+#define epicsEventTrigger(ID) \
+ (semGive((SEM_ID)(ID)) == OK ? epicsEventOK : epicsEventError)
#define epicsEventWait(ID) \
-(semTake((SEM_ID)(ID),WAIT_FOREVER)==OK ? epicsEventWaitOK : epicsEventWaitError)
+ (semTake((SEM_ID)(ID), WAIT_FOREVER) == OK ? epicsEventOK : epicsEventError)
- Re: [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base Andrew Johnson
- [Merge] lp:~anj/epics-base/epicsEvent-api into lp:epics-base noreply
Project ideas for the Codeathon Andrew Johnson
<2011>
<2011>
