2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: EPICS statistics on oholo.net
To: [email protected]
Date: Fri, 7 Jan 2011 12:48:24 -0600
Hi Nick,
On Friday 07 January 2011 12:10:50 [email protected] wrote:
> Does anyone know where the EPICS line count statistics on
> https://www.ohloh.net/p/epics-base/analyses/latest come from?
> What gives? Is EPICS half as big as I thought it was?
Ohloh is configured (under Development -> Enlistments if you're sufficiently
privileged) to look for EPICS Base code in 3 separate Bazaar repositories, for
3.13, 3.14 and the old cvs-trunk (which is where Jeff has been working).  I've
just added the new 3.15 repo to its list as well, but it won't download and
include those stats until it gets to the front of its queue.  I'm guessing
that it has just added up the totals from those 3 repo's in reporting the
counts.
That would imply we should probably configure it with just one Bazaar repo for
the online stats to make sense.  The question is which one...
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it.  If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence.  -- Bertrand Russell
Re: EPICS statistics on oholo.net Andrew Johnson
EPICS statistics on oholo.net nick.rees
Prev: RE: EPICS statistics on oholo.net Davidsaver, Michael
Next: Re: EPICS statistics on oholo.net Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  2010  <20112012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
