2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: src/ reorganization (merge request)
To: <[email protected]>
Date: Mon, 20 Dec 2010 17:36:52 -0500
> -----Original Message-----
> Sent: Friday, December 17, 2010 2:44 PM
> To: Andrew Johnson; [email protected]
> Since there is agreement (or at least silence) on this I'm going to
try
> to finish this today.  Given peoples schedules I assume the merge will
> wait until 2011.
Ok, that took longer than I expected, but it is ready now.  I tried
building synApps 5.5 against it and the only problem I found was
streamdevice having code with #ifdef EPICS_3_14.
With this change Base build the following libraries:
libca.so.3.15
libcas.so.3.15
libCom.so.3.15
libdbCore.so.3.15
libdbRecStd.so.3.15
libdbStaticHost.so.3.15
libgdd.so.3.15
EPICS_BASE_IOC_LIBS = dbRecStd dbCore ca Com
dbStaticHost will go away when Andrew's perl replacements are merged.
I make a "fix" in src/libCom/tools/flex/parse.y which will probably need
to be re-fixed.  There are now two 'main.c' files in CPP search path for
libCom.  I wasn't sure if renaming would cause problems when merging
future updates for flex.
Also, what should be done with all the .rc file?  Do they need to be
merged?
dbCore_RCS = dbStaticIoc.rc registryIoc.rc dbIoc.rc asIoc.rc
dbtoolsIoc.rc rsrvIoc.rc miscIoc.rc
I've started a merge request so please direct comments/requests there.
https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src/+merge/4429
6
Michael
src/ reorganization Davidsaver, Michael
RE: src/ reorganization Davidsaver, Michael
Re: src/ reorganization Andrew Johnson
Prev: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base mdavidsaver
Next: Re: [Merge] lp:~mdavidsaver/epics-base/reorg-src into lp:epics-base Ernest Williams
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: src/ reorganization Jeff Hill
Next: RE: src/ reorganization Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
