2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: RE: src/ reorganization
To: "Andrew Johnson" <[email protected]>, <[email protected]>
Date: Fri, 17 Dec 2010 14:44:25 -0500
Step 2 is done:
https://code.launchpad.net/~mdavidsaver/epics-base/reorg-src
Should libCom/test/fdmgrTest be moved to ca/client/test/?  It is testing
functionality in libCom, but uses parts of libca.  Currently it isn't
(and wasn't) being built.
Step 3 will merge libraries in libCom/ and ioc/.
libCom will include asHost and rtemsCom.
libdbCore will consist of dbStatic, db, registry, bpt, dbtemplate, rsrv,
and misc
libdbRecStd will consist of rec, dev, and softIoc
The unit tests will remain in separate directories.
Since there is agreement (or at least silence) on this I'm going to try
to finish this today.  Given peoples schedules I assume the merge will
wait until 2011.
Michael
Re: src/ reorganization Andrew Johnson
RE: src/ reorganization Jeff Hill
RE: src/ reorganization (merge request) Davidsaver, Michael
src/ reorganization Davidsaver, Michael
RE: src/ reorganization Davidsaver, Michael
Prev: RE: src/ reorganization Davidsaver, Michael
Next: Re: src/ reorganization Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
