Hi Michael,
On Friday 10 December 2010 11:47:32 Davidsaver, Michael wrote:
> In the interest of not doing too much at once I'd like to do the
> reorganization in stages. The first stage to be just moving whole
> directories. The second would be file moves. Third would be merging
> the lib*Ioc libraries. The intent is that to ensure that things remain
> buildable after each step.
Sounds good. Please remember to check that the makeBaseApp templates still
work while you're doing that.
> If there aren't major changes then next week I will create a branch with
> these changes and request a merge.
> The first stage will look like:
> > == Full list of renames
> > tools = tools
> > libCom = libCom
> > toolsComm = libCom/tools
> > RTEMS = libCom/RTEMS
> > as = ioc/as
> > bpt = ioc/bpt
> > db = ioc/db
> > dbStatic = ioc/dbStatic
> > dbtools = ioc/dbtemplate
> > misc = ioc/misc
> > registry = ioc/registry
> > rsrv = ioc/rsrv
> > dev/softDev= std/dev
> > dev/testDev= std/test
> > rec = std/rec
> > softIoc = std/softIoc
> > ca = ca/client
> > cap5 = ca/client/perl
> > catools = ca/client/tools
> > cas = ca/legacy/pcas
> > excas = ca/legacy/pcas/ex
> > gdd = ca/legacy/gdd
> > makeBaseApp= template/base
> > makeBaseExt= template/ext
> > util = util
One question about the layout: I'm wondering whether in the final structure
individual directories should either be a branch node or a leaf node, i.e.
they should either contain sub-directories and a Makefile, or they contain
source files and a Makefile, but never both. Your ca/client and
ca/legacy/pcas directories are currently mixed nodes.
The existing db directory is structurally a mixed node, but to the build
system the db/test directory is an immediate child of the src/Makefile.
The libCom directory is a weird combination, because while there are no source
files in src/libCom that's where the Makefile is that compiles everything and
where the O.* directories are created. Most of the libCom/* sub-directories
do not contain Makefiles, except for libCom/test which the build system treats
as another immediate child of src/Makefile.
Was your intention to follow the libCom model for source directories? My
worry is that the libCom/Makefile is unwieldy because it has to name all of
the files in the different sub-directories. I am looking at a fix for that
though, moving those parts into Makefile fragments that live next to their
associated source files.
- Andrew
If a man is offered a fact which goes against his instincts, he will
scrutinize it closely, and unless the evidence is overwhelming, he will
refuse to believe it. If, on the other hand, he is offered something
which affords a reason for acting in accordance to his instincts, he
will accept it even on the slightest evidence. -- Bertrand Russell
- RE: src/ reorganization Davidsaver, Michael
- src/ reorganization Davidsaver, Michael
Re: src/ reorganization Ben Franksen
Re: src/ reorganization Andrew Johnson
<2010>
<2010>
