2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base
Date: Mon, 25 Oct 2010 17:14:44 -0000
> Minor issue: We already have a macro EPICS_DEPRECATED in
> compilerDependencies.h which expands out to __attribute__((deprecated)) on
> GNUC.  Please use this in dbScan.h instead of your __attribute__() macro, we
> have worked hard to keep architecture-specific code in certain areas of the
> code-base only, preferably within libCom.
OK. I missed that macro. And I have a typo in my macro. I forgot the trailing __ for the non-gnu compilers. (has nobody tried to compile this on Windows so far?)
https://code.launchpad.net/~dirk.zimoch/epics-base/named-soft-events/+merge/26190
Your team EPICS Core Developers is requested to review the proposed merge of lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base.
Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Andrew Johnson
Prev: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Andrew Johnson
Next: Re: [Merge] lp:~dirk.zimoch/epics-base/named-soft-events into lp:epics-base Dirk Zimoch
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
