2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Channel Access and Virtual IPs
To: EPICS core-talk <[email protected]>
Date: Thu, 23 Sep 2010 13:12:09 -0400
 Hi Ernest,
On 23.09.2010 11:14, Ernest L. Williams Jr. wrote:
Does CA fully support virtual IPs on a linux host?
For applications, there is no difference between virtual and real network interfaces.
The CA client supports virtual IPs. (That does not need specific code in the client, so it always has.)
Only the CAS server supports binding to specific IP addresses (virtual or real), the rsrv server (IOC) does not.
Or are we still waiting on the merge fo rsrv and pcas?
Either that, or someone extending rsrv to support binding to a specific IP address (and honor the environment variables that control this).
Cheers,
Ralph
Channel Access and Virtual IPs Ernest L. Williams Jr.
Prev: Channel Access and Virtual IPs Ernest L. Williams Jr.
Next: Re: [Merge] lp:~epics-core/epics-base/apple-ios into lp:epics-base Janet B. Anderson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: 3.14.12 Release Planning Andrew Johnson
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
