On 08.09.2010 18:57 Benjamin Franksen wrote:
On Donnerstag, 9. September 2010, Andrew Johnson wrote:
I'll be on vacation until next Wednesday now.
I don't like the keyword "scope", can you find some other word
instead? It has too much of a "computer-science theory" connotation.
Even "block" would be better, but that's not very descriptive
either.
I'll try to come up with something that doesn't scare people off, is
reasonably short, and still conveys the meaning. Any suggestions
anyone?
What about "group"?
From all the stupid ideas that I had, this sounded most applicable and
comprehensive even to non-geek people.
BTW: I assume that every call to msi will implicitly be a group. Will -
in addition to that - also each substitutions file have its own implicit
group? (Making it work much like C file scope.)
The crucial issue is how concatenating subst files and running msi on
the result will differ from running msi on the same set of subst files.
(That was a Diamond use case, iirc.)
Seems I finally have to make myself comfortable with bzr & launchpad. I
suppose I have to create a branch on lp, separate out the agreeable
stuff from the msi-join branch, put them on mine, publish it and and
propose a merge. Have I got that right? Oops, never mind, I just found
the wiki page that explains everything.
For convenience I would strongly suggest to install and try the QBzr
plugin, which adds quite nice and easy-to-use GUI versions of nearly all
bzr commands.
What is the schedule for R3.14.12?
ASAP.
I think before the EPICS meeting would be nice.
Cheers,
Ralph
- Re: msi again Ben Franksen
- Re: msi again Benjamin Franksen
- Re: msi again Andrew Johnson
Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Marty Kraimer
Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Ralph Lange
<2010>
<2010>
ANJ, 02 Feb 2012 |
Home
News
About
Base
Modules
Extensions
Distributions
Download
Search
EPICS V4
IRMIS
Talk
Bugs
Documents
Links
Licensing
