2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Dynamic Loading and Unloading of EPICS Device Support and Record.
Cc: [email protected]
Date: Thu, 09 Sep 2010 05:56:25 -0400
 On 09/08/2010 04:09 PM, Ben Franksen wrote:
On Mittwoch, 8. September 2010, Eric Norum wrote:
What's the use case for this, anyhow?
Yes, I would be interested in that, too.
The following is not for an embeded system but does show a good use for on-line add and delete.
Guabao Shen (BNL) is developing a "gather" service. The service uses a javaIOC. The javaIOC has gather records. Each gather record collects data from a set of caV3 records and provides the result to the client as an array.
The javaIOC also has a createGather record. The client supplies a list of channels to the createGather record. When the record processes it creates and installs a new gather record. The gather record can be temporary or permanent. If the record is temporary than after no clients are attached to the record for some fixed period of time the gather record is automatically deleted. If it is permanent it can be deleted by request.
Both on-line add and delete are required in other for this to be a robust service.
Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Ralph Lange
Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Ben Franksen
Dynamic Loading and Unloading of EPICS Device Support and Record. Ernest L. Williams Jr.
RE: Dynamic Loading and Unloading of EPICS Device Support and Record. Geng, Zheqiao
Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Eric Norum
Prev: Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Ben Franksen
Next: Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Marty Kraimer
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: Re: Dynamic Loading and Unloading of EPICS Device Support and Record. Ralph Lange
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
