2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp
To: Jeff Hill <[email protected]>
Cc: "'EPICS Core Talk'" <[email protected]>
Date: Wed, 18 Aug 2010 10:52:16 -0400
 Hi Jeff,
On 17.08.2010 20:05, Jeff Hill wrote:
Hi Ralph,
I'm not sure about that race condition, though.
But don't see where my fix would break the fixed behavior, as it is
still using a countre, decrementing the iiuExistenceCount is still
happening at the end of cac::destroyIIU(), and incrementing
iiuExistenceCount (original fix) happens exactly when it is added to
the
list, so that (my fix) using circuitList.count() to set
iiuExistenceCount yields the same result.
The cac::destroyIIU has roughly three sections of code. In the first section there is a lock protected remove of the per-tcp-circuit data structure from cac's list etc, in the second section the per-tcp-circuit destructor is run without holding the lock so we will not deadlock, and in the third section we are protected by the lock when returning the per-tcp-circuit's memory to the free list and decrementing the iiuExistenceCount.
So, of course the business at hand is that we need to prevent the cac destructor from finishing until each of the tcp circuits is completely shut down. We do not make the cac destructor wait for the list count to become zero because we have to wait for stuff that happens after the per-tcp-circuit is removed from the list. Hence the need for the iiuExistenceCount.
Note that _multiple_ threads, each managing private TCP circuits, can all be shutting down simultaneously and that the lock is released briefly between removing the circuit from the list, and decrementing the iiuExistenceCount.
Thanks for the explanation.
But - as I said in my mail - I perfectly understand bug #541362 and see why a counter fixes the issue that appears when using a simple flag.
My point is: my fix did not change the code in cac::destroyIIU at all. I also did not switch back to looping over the circuitList.count() instead of looping over iiuExistenceCount. My fix just switched from gradually increasing iiuExistenceCount whenever a new circuit gets added to the list, towards setting iiuExistenceCount to circuitList.count() under the lock before shutting down the circuits. As (in your fix) iiuExistenceCount++ happens immediately after adding the circuit to the circuitList(), I still think these two versions are equivalent.
Sorry about insisting here ... This is really not about trying to always be right, I just want to understand why I'm wrong.
  Furthermore, at the same instant in time it is possible that a new TCP circuits might also be created.
How?
The only way a new circuit gets created is after an incoming result of the name resolution process. The UDP task has been shut down earlier in the cac dtor. Who is creating the new circuit?
  So setting the count to the number of items on the list can seriously scramble the proper state of the iiuExistenceCount even before the cac dtor runs.
iiuExistenceCount is not used outside the cac dtor. I am setting it inside the dtor with the lock being held. I don't see how it can be scrambled after that, and a variable being scrambled before it is set is not relevant.
  And of course if that happens then we can have a crash because the cac dtor might not wait for all of the threads managing the circuits to shutdown, or alternatively hang forever waiting for phantom circuits to shutdown.
Using your fix, if circuits are added after the unlinkAllChannels block (line ~290), they will be waited for in the line ~307 loop (as iiuExistenceCount is increased), but unlinkAllChannels has never been called for them, so the loop will hang forever. Afaik this behavior has never been observed, which I would take as a hint that shutting down the UDP task first reliably keeps new circuits from being created at that time.
(This has changed with the introduction of TCP name requests - but that's the other mail thread.)
Cheers,
Ralph
-----Original Message-----
Sent: Tuesday, August 17, 2010 10:08 AM
To: Jeff Hill
Cc: EPICS Core Talk
   Hi Jeff,
thanks for the fix!
In my fix:
Setting iiuExistenceCount to the circuitList.count() (line ~290)
happens
in the cac::~cac destructor while the lock is being held, immediately
followed by calling unlinkAllChannels() on all circuits in that list.
The only place where the lock is given up is one block down (line
~307),
when waiting for the tcp threads to exit.
What race condition are you seeing? I looked at the 11786 change and
bug#541362. I perfectly see why a counter fixes the issue that appears
the
I'm perfectly fine with using the original (increment) fix, but I would
like to understand where the difference is.
I think I also see another new race condition introduced by ca-over-
tcp,
which probably breaks the shutdown behavior for clients using
ca-over-tcp, and needs to be fixed.
When the lock is given up in cac::~cac() and the loop (line ~307) waits
for termination of all TCP tasks, an incoming name-res reply from a
still active TCP circuit (the UDP task has exited by that time in the
cac::~cac destructor) could open a new circuit (tcpiiu.c #2188), which
would then be added to the circuitList (and iiuExistenceCount be
incremented). For that new circuit, that the loop would be waiting for,
unlinkAllChannels() is not being called, so it does not have a reason
to
terminate its threads.
Maybe we still need a flag: to avoid creating new circuits while the
cac:~cac destructor runs?!
What do you think?
Thanks a lot,
Ralph
On 16.08.2010 19:46, Jeff Hill wrote:
+ this->iiuExistenceCount = this->circuitList.count();
Examining this change a bit closer I see that it will introduce a
race condition when circuits are being created and destroyed at close
to the same instant in time. See revision 11786 of cac.cpp which fixes
mantis 334 if you are interested in what this code does. After running
the regression tests, I pushed in a fix (which is removing above
mentioned change and restoring the increment of iiuExistenceCount in
cac::findOrCreateVirtCircuit.
Jeff
Sent: Monday, August 16, 2010 10:03 AM
To: Andrew Johnson
Cc: Jeff Hill; EPICS Core Talk
Subject: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp
    Hi Andrew,
it looks as I have found the reason for the segfaults, which I think
is
a bug in CAC.
In the cac::~cac() destructor, a private member
"this->iiuExistenceCount" is used to determine if cac should wait
for
TCP threads to shutdown. While this counter gets correctly decreased
in
cac::destroyIIU(), it never gets increased or set (except
initialized to
0 in the cpp constructor).
So cac::~cac() was never waiting for the TCP threads to shutdown,
and
happily kept tearing down the timer/mutex infrastructure. If the
threads
were not fast enough, they were hitting on destroyed semaphores when
cancelling their watchdog timers - that was causing the exceptions
and
segfaults.
This one-line fix will take care of the problem:
=== modified file 'src/ca/cac.cpp'
--- src/ca/cac.cpp      2010-04-15 21:06:16 +0000
+++ src/ca/cac.cpp      2010-08-16 15:24:13 +0000
@@ -287,6 +287,7 @@
                // shutdown all tcp circuits
                tsDLIter<   tcpiiu>   iter = this-
circuitList.firstIter ();
                while ( iter.valid() ) {
                    // this causes a clean shutdown to occur
Maybe it actually takes care of several shutdown related issues...
Yay!
Ralph
RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Prev: RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
Next: Re: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Ralph Lange
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Next: RE: Fixed: Segfaults in 3.14 branch since merging ca-over-tcp Jeff Hill
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
