Subject: |
Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base |
Michael Abbott <[email protected]> |
To: |
[email protected] |
Date: |
Mon, 05 Jul 2010 08:59:22 -0000 |
Well, I've responded to Jeff's review comments.
* I've updated the version number and guard from 4.12 to 4.13. Of course, this means that this branch really does need to be merged after the TCP-based search requests feature.
* Rather than think very hard (and maybe make a stupid mistake) I've just guarded the memset() that Jeff flagged with the obvious sanity test.
* I've re-merged with EPICS base. As I noted on the mailing list, this introduced a massive merge conflict with the variable renaming in db_access.c, but as the renaming is quite gratuitous I simply dropped that part of the merge.
* I'm sorry, I've not done anything to acctst.c. As far as I can see it's client side only, and I don't really see where to get started without spending a *lot* of time on it. I'll try and look at this again another time.
https://code.launchpad.net/~michael-abbott/epics-base/dynamic-array/+merge/26796
Your team EPICS Core Developers is requested to review the proposed merge of lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base.
- [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Dirk Zimoch
Re: [Merge] lp:~dirk.zimoch/epics-base/fix-aai-and-aao into lp:epics-base Andrew Johnson
<2010>
RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base Jeff Hill
Using C++ keywords as variable names in C code Ralph Lange
<2010>
