2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024  Index 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Subject: Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base
To: [email protected]
Date: Thu, 24 Jun 2010 09:31:54 -0400
Hi Nick,
On Thu 24 Jun 2010 4:54:51  wrote:
I don't think that acctst is a valid epics test harness. I suggest we
also look at turning it into one so that it is run with make runtests
(and also with our automated test system). Is this a sensible idea?
Definitely.
Even more definitely it's not an easy task, as acctst involves things like pulling and reinserting the network plug in the IOC to check tcp circuit timeout/cleanup etc..., stuff that is not easily automated.
Don't want to discourage you, just .... it's going to be fun :-)
Ralph
Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Andrew Johnson
[Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Michael Abbott
Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Jeff Hill
RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base nick.rees
Prev: Re: Merges: 3.14.12 vs 3.15 Ralph Lange
Next: Re: [Merge] lp:~michael-abbott/epics-base/dynamic-array into lp:epics-base Andrew Johnson
Index: 2002  2003  2004  2005  2006  2007  2008  2009  <20102011  2012  2013  2014  2015  2016  2017  2018  2019  2020  2021  2022  2023  2024
Prev: RE: [Merge] lp:~michael-abbott/epics-base/dynamic-array intolp:epics-base nick.rees
ANJ, 02 Feb 2012 Valid HTML 4.01! · Home · News · About · Base · Modules · Extensions · Distributions · Download ·
